Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 132 33 34 35 3643 Next
PostPosted: Sun Sep 11, 2016 10:50 pm
I agreed with you in advance. ;)
If that's true then "Maximum Gain" (wich is basicly AGC drive) in Omnia.9 is working wrong.
I wouldn't expect Maximum Gain and Drive to do the same thing. In processors I have seen that employ a Drive control, it is simply an amplifier immediately before that processing stage. Or at least that is how it appears to function in processors I have dealt with.
Leif's "Maximum Gain", and Hans' "Drive", do not operate the same way.
Leif's actually has a real 0dB which everything is centered around. As long as the bands aren't running out of range, and you're not using progressive release, you're free to adjust the Maximum Gain setting, and there will be NO change to the audio. Even with non Infinite:1 ratios. Similarly... adjusting the ratio of his AGC (or "a band") that's at 0dB will have no effect on the average loudness of the audio at that given moment.
Hans' AGC and multibands have 0dB at the top, so changing the drive will change the sound if there's a non-Infinite:1 ratio being used. There's no way around that, without copying what Leif did.
PostPosted: Mon Sep 12, 2016 12:10 am
https://www.youtube.com/watch?v=XEe-LB8VzEI
Hans van Zutphen in this video :)
PostPosted: Mon Sep 12, 2016 9:06 am
I found what causing this "step". It`s the "Hard limit"
PostPosted: Mon Sep 12, 2016 11:35 am
I can not get the right and left stereo separation is not beautiful instrument sounds
PostPosted: Tue Sep 13, 2016 1:16 am
Good video, nice to see interest in bandwidth limiting.
I would like to see some way to manage stereo width in ST / SST at least with 2 frequency areas, below and above 700 Hz.
[edit]
Actually... I did figure out a way to get closer to what I want to do with the stereo image. It's attached. I need to work on it more, but it's not bad so far. :) It would be better if ACR was just capable of limiting the amount of total stereo output in at least 2 frequency areas... vs just having control over what's being added and just broadband... since I don't like "stereo boost" as much.
[/edit]
Jesse Graffam - Stereo Settings Test 2016-09-13.sts [1.53 KiB]
Downloaded 354 times
PostPosted: Sun Sep 18, 2016 12:01 am
Well, it would be nice to have graphically controlled stereo width, in the same way as eq or phase shift. With range from total mono to wider stereo (200%? 400%?). I miss this option a little (i like "center bass" and slight widening around 2-4kHz, but not widening "sparkle" above 10kHz)..
PostPosted: Sun Sep 18, 2016 12:55 am
Fixed:
- Matt/Joop barrel shape thing: Split Ratio into Start and Maximum Ratio. Note: I don't know if this is good or not yet. I added this feature after talking to several people, and on one hand it seems to make sense (in dynamic tracks, short quiet moments will get louder and short bursts will get quieter), but on the other hand it might also be bad (making the loud bursts quieter might make dynamic tracks sound softer than non-dynamic tracks, which is the opposite of what we want). Waiting for feedback, if this is bad I'll remove it again. Note: With setting lower than the Start Ratio (for example the default value of 1.00), the Maximum Ratio is ignored.
Windows stand alone: http://www.stereotool.com/download/ster ... 01-037.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-037.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-037.dll
- Crash at Koek
- Edwin vdP's True Bass idea
- OHW
- Crash reported below
NOW:
- PC for Nautel TUESDAY
- Email customers! TUESDAY
- SST FINAL BUILD
- FM analyzer! ORDERED WEDNESDAY
- Measure latency WEDNESDAY
- Fill USB sticks THURSDAY
IBC PREPARATION:
STEREO TOOL RELEASE:
- Latency issue: Is it higher than before? And what to do with people who are updating? LATER
- Release
- "This sound is processed by" in versions with different names. How to handle that?
- 14 september speed date ideeenfabriek
DONE:
- FB post
- Andere analyser installeren
- Sound cards! Arrived! WEDNESDAY TO RAI 2x
- Check Axia mixer OK! GET WEDNESDAY
- Fancy name tags ORDERED
- Fast pc! ORDERED Mathijs
- Connector tulp male naar XLR male
- Make full IBC setup
- SST 2 knoppen PNR
- "Force higher level action" must also be performed for server events!
- PNR RESET button does not get enabled/disabled
- MicroMPX bug: -a "Card name" does not work!
- Run Valgrind for MicroMPXMathijs
- Rename PNR Noise & Hum to Dehummer?
- Crash when zooming out in waveform fixed. (Has been present for a long time, but was almost impossible to reproduce).
- Declipper waveform was wrong for Quality > 100%.
- Crash Leif?? (Maybe bad server data?) - Not seen anymore, several bugs fixed - hopefully gone
- Myeasylog.log
- Crash with test tones -> Old beta (015), ignore.
- Cleanup presets
- SST presets
- "Load processing" skips Clipping - No was old file.
- Help page with power user markings. Some settings (sound cards) should not be marked.
- STAND ALONE VERSIE in SST mergen
- Als saved en Load onder All Audio setting dan is Over Sampled Limiting and Clipping uit geschakeld -> Seems to work as designed (which is different from before though). -> Changed back for Stereo Tool
- Sync: Handle big difference between clocks. More than .01% is probably already too much. Then ignore. Add a parameter, set to 0.1%.
- Crash reported by Wouter Tietema, probably caused by low latency monitoring output. - probably fixed.
- Sync: Was adjusting new constant offset from Normal to FM output in wrong direction.
- Edit: I see occasional jumps in the output VU meter. They are *not* present in the scope or in the sound card output. Will check.
- Stand alone HTML5 GUI FRIDAY
- Linux Fedora issue
- Make MAC version HELP work. (tonight) - to be tested
- Remove LQLL HQ mode (non-SST) (tonight)
- Check VMware flag turning ON for unknown reason (tonight) -> Not changed recently, and seems not to cause problems, so ignoring for now.
- Fixed synchronization problem between meters, scropes and audio
- INDEX.HTML automatisch resolven
- Add no cache to objects.js!!!
- Declipper broken according to DJ_DOGGY, so far unable to reproduce!
- Change version number
- Crash in BETA029 fixed.
- Linux Rivendell version -> Returns silence in FM output, why??? Add logging! --> _ST_AUDIO define! But why does it work in Windows?
- Kill License SST
- Remove warnings
- Check red output bars for 'Rules are there to be broken' - overshoots and clicks present.
- Make new separate Presets class ->
- Check and solve Linux Valgrind errors for Declipper
- Linux high CPU load
- Solved Low Latency mode crash
- Previous version could crash on startup. Should be solved now.
- White list IP's?
- Add Declipper main view
- Gain works again
- Type IP in web site
DONE IBC:
- Email NAB visitors
- Images for booth presentations Mathijs
- Images for ST presentation
- USB sticks!!! ORDERED ARRIVED
- Business cards Matt ORDERED ARRIVED
- Call Karlex CALLED, WILL BE SHIPPED.
Later:
- Update website LATER
- CHECK CRASH with VLC - VLC related?? Not seen anymore, later.
- Web interface export preset
- Generate UIDs and use link
- Password for login?
- Run as a service
- Websockets? Later
- Remove inputOldSamplesFixedCopy, should not be needed if I split WAVE from VU meter calculations.
PostPosted: Sun Sep 18, 2016 3:22 am
What about "Stereo Image" > Center bass.
Result which i hear is so "cold". What about new feature?
I want to choose mono freq range and slope.
Maybe you will add this feature in future?
Sorry for bad english.
Best regards,
Ilia.
PostPosted: Mon Sep 19, 2016 5:29 am
Quality up to 100% will be possible at some point?
The preset "Eleventh Haeaven" sounds great to 120%, but there are some small jumps in some songs
PostPosted: Mon Sep 19, 2016 5:31 am
Are you running StereoTool or Omnia SST? Values greater than 100% are not supported in StereoTool.
I'll let Hans come in here and educate further, as he desires. But I would not recommend going into a text editor and kicking that setting up any higher than 100%. Not only will it not work, but it might have negative consequences such as the one you've observed.
