Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 1 2 3 4 5 643 Next
PostPosted: Sun Jul 10, 2016 9:03 am
Arrr.. the joys of the 'quick patch'... :cry:
PostPosted: Sun Jul 10, 2016 10:49 am
When i load a preset in Extreme Tweaker mode and i switch to Simple mode.
I get alignment problems with:
Sound cards->FM Output->Synchronize to output
FM Transmitter->RDS volume
PostPosted: Sun Jul 10, 2016 12:35 pm
Hey Hans,
Since Beta801-002 I have no sound coming out from stereotool.
I use it as VST plugin in Wavelab Elements 7.
Version 801-001 is ok.
Peakmeters in stereotool are working
PostPosted: Sun Jul 10, 2016 3:58 pm
Beta 03
is running well, just as Beta 02
* Memory in HD mode is about 297,5 MB
* Memory use in FM mode is about 302,6 MB
* Declipper seems ok, after re-loading ST.
* in delossifier, Input/ Output spectrum screens doesn't match frames (in 1920x1080 mode)
PostPosted: Mon Jul 11, 2016 12:57 am
I found one bug that might explain all kinds of undefined behavior, if this version still causes problems I'm adding logging tomorrow.
Windows stand alone: http://www.stereotool.com/download/ster ... 01-004.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-004.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-004.dll
Known issues:
PostPosted: Mon Jul 11, 2016 7:22 am
Stand Alone on Win 7 64 same crash results as Betas 2 and 3 for me.
C.
PostPosted: Mon Jul 11, 2016 8:33 am
Every beta from this topic crashes at start on my win7 64, I removed all old settings and nothing..
Regs
Urban Junglist
PostPosted: Mon Jul 11, 2016 10:31 am
I'm not getting crashes on Windows 10 64-bit through Winamp, but I AM having the "no sound" problem described by others.
The meters all move, everything looks like it's working, but it's absolute silence to my sound card.
When I "bypass processing," the audio comes through. I switch processing back on, and... nothing.
If you'd like me to test anything, please let me know and I'll do my best.
Gene Savage
BlackLight Radio
https://BlackLightRadio.com
Tulsa, Oklahoma USA
PostPosted: Mon Jul 11, 2016 12:27 pm
Looks like there will be "logging is in tha house" :)
PostPosted: Mon Jul 11, 2016 1:05 pm
Ok, now I've added error handlers for all the 58 (!) new threads that are running - at least I hope I didn't miss anything. So, instead of closing, you should get a popup with error codes. Which I can use to find the error.
Windows stand alone: http://www.stereotool.com/download/ster ... 01-005.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-005.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-005.dll
Known issues:
- Crashes on some systems
