Post new topic  Reply to topic  [ 49 posts ]  Go to page Previous 1 2 3 4 5 Next
 Post subject: Re: Raspberry Pi
PostPosted: Thu Sep 24, 2015 3:23 pm
Probably, but the Pi is so easy to obtain... Anyway I'll make a short video later today to show what I can do with it now.
PostPosted: Thu Sep 24, 2015 6:24 pm
Video, as promised!
https://www.youtube.com/watch?v=tVCw59m ... e=youtu.be
Downloads are now available here:
viewtopic.php?f=14&t=6164&start=50
PostPosted: Fri Sep 25, 2015 3:05 am
If it will do at minimum the AGC auto gain, multiband compressor/limiter and final limiting, that would be plenty enough for those who wanted to build a part 15 AM transmitter.
Nice video. Will have to watch it on another computer though as it is choppy on my current desktop.
PostPosted: Fri Oct 02, 2015 10:03 pm
I wanted to test how does stereotool work on my raspi2, but unfortunately jackd not supported I2S DAC :(
PostPosted: Wed Nov 11, 2015 2:08 am
Can you pls tell me how to install on PI 2 ?
I download the StereoTool but i dont know how to install/run on Pi2
Thanks!
Sexy Girls in your city
PostPosted: Wed Nov 11, 2015 2:37 am
Thanks!
Just download it. I still need to post it on the download page btw (I haven't had time yet to build it).
Since there are some other bugs reported now, I'll probably release it with version 7.81.
PostPosted: Wed Nov 11, 2015 2:40 am
Thanks!
i did download it... by the page and i see the file on downloads, then what? :P
how to install or run ?
PostPosted: Wed Nov 11, 2015 2:59 am
Just to check: You downloaded the BETA008 Raspberry Pi 2 version?
If so you have an executable and you should be able to just run it. If it doesn't work, please try running it from a terminal window so you can see any error message.
When you start it, you probably have to type ./ before the file name so something like this:
./stereo_tool_BETA774-008
If you get an error message that the file isn't executable (I don't think that happens on a Pi though), you need to chmod it to 775:
chmod 775 stereo_tool_BETA774-008
(In both cases, fill in the exact file name)
PostPosted: Wed Nov 11, 2015 3:13 am
Yes, 008 i have download.
I double click the file to run. It shows like loading and then nothing happens. I also try to open via Terminal, but i could nt
i dont know why its not running.
PostPosted: Wed Nov 11, 2015 3:18 am
ok i found it...
Need to chmod 775 stereo_tool_BETA774-008
thanks!
