Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1 2 3 4 5 6213 Next
PostPosted: Sun Feb 20, 2011 10:33 pm
lol. I'd like the know what was under the "Black chicks w..." minimized windows tab there. ;)
-n4-
PostPosted: Mon Feb 21, 2011 12:58 am
LMAOOOOO :D
PostPosted: Mon Feb 21, 2011 1:52 am
Auwtch :shock: :shock: :shock:
PostPosted: Mon Feb 21, 2011 1:58 am
Hey to each his own lol.
PostPosted: Mon Feb 21, 2011 4:38 am
I'm not sure if this is any good, but here's a version with a different AGC: 'up speed' is now no longer controlled by how far the volume is dropped, but by how much difference there is between the current amplification and the maximum amplification possible at each moment. So now the volume goes up in a constant speed (dB/s) instead of fast when the volume is really low and slowly if it's near the top. This has quite some impact on the AGC behavior - feedback is welcome....
(Actually I only changed 2 lines of code, but the difference is pretty big).
Note: I just realized that this change also impact the de-esser filter in Loudness, probably in a bad way...
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-002.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-002.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-002.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-002.dll
Command line version: http://www.stereotool.com/download/ster ... 20-002.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-002 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-002 NOT AVAILABLE
PostPosted: Mon Feb 21, 2011 5:58 am
pretty much same for me...
PostPosted: Mon Feb 21, 2011 6:00 am
You probably need to increase Up Speed - it works MUCH slower than before for most tracks.
Increasing Up Speed has little effect for tracks with a very constant volume - and for tracks with much dynamic differences you WANT to make it act more aggressive.
I have increased Up Speed from 0.800 (default) to around 10.0 to get good results. Also make sure not to set Down Speed too high (not above ~ 10).
Question: Are you comparing ITU-1770 differences? Because - since I've disabled ITU-1770 processing - that might have a big impact, especially since this Abba track has little highs. And highs are counted more strongly in ITU-1770.
Maybe - just maybe - ITU-1770 is possible again with this new AGC processing (because I think it might impact loud voices such as in that Celine Dion Titanic track a bit less).
PostPosted: Mon Feb 21, 2011 6:14 am
I already done that and other presets and all combinations... in current preset i already have up speed to 1.767 and down to 11.728.
..i just compared with v6.10.
Dynamic tracks are about at same level, but louder track are, maybe 0.5dB lower in 620b002
edit: UpSpeed to 10.0 ?
PostPosted: Mon Feb 21, 2011 11:13 am
Yes... There's a 'brake' in the current implementation: Up speed is multiplied by something like 1 - (current input level / previous peak level) - so if the input volume is reduced slightly, up speed is far smaller than the specified setting.
But actually I think adding ITU-1770 again will have far more impact.
PostPosted: Mon Feb 21, 2011 1:44 pm
Too good a change. Very constant volume with Preamp 10~18 and AGC settings of 10.0/10.0(I disabled Bass AGC for the sound gets very boomy and induces pumping even after lowering the attack/release settings).
A small caveat when (not because of AGC) used with Multiband...probably got to do with the fact that MB doesnot have lookahead I guess....Sound with just AGC enabled is remarkably constant, but begins to pump or breathe as MB is enabled. Effect is more felt with Top Limiter set to Limit than when set to Compress. But no gripes with AGC alone.
...since I've disabled ITU-1770 processing - that might have a big impact, especially since this Abba track has little highs. And highs are counted more strongly in ITU-1770.Maybe - just maybe - ITU-1770 is possible again with this new AGC processing (because I think it might impact loud voices such as in that Celine Dion Titanic track a bit less).
Does enabling ITU-1770 in sts Enable it in Stereo Tool really for now?
visit website
