Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 128 29 30 31 3243 Next
PostPosted: Fri Sep 02, 2016 9:44 am
I managed to reproduce both now. And fortunately they seem to be related. Trying to find the cause now.
PostPosted: Fri Sep 02, 2016 1:42 pm
I'm running the standalone version and I see it. Had Wes's preset loaded at the time, but I see it on 7 Wonders too. I don't see it on the scopes, but I do see it on the mpx meter.
PostPosted: Fri Sep 02, 2016 2:29 pm
DJ DOGGY, or Hans, pls give me a stream url that works for you on ST, to try it.! I cant make it work.. maybe i do something wrong.!
Sexy Girls in your city
PostPosted: Fri Sep 02, 2016 2:38 pm
http://pub1.di.fm:80/di_techno
you must hear some voice to explain something
PostPosted: Fri Sep 02, 2016 3:17 pm
no... i copy paste it and no sound, nothing..! What do i do wrong?
PostPosted: Fri Sep 02, 2016 5:37 pm
Have no idea - try uninstall, restart and reinstall VLC .
PostPosted: Fri Sep 02, 2016 5:47 pm
I hear that voice too.
To make sure that Stereo Tool really sees VLC, please try this:
1. Select another input sound card
2. CLOSE Stereo Tool
3. Open Stereo Tool again, then check if VLC is still in the list.
Why: If you open Stereo Tool and the sound card that it wants isn't available, I don't want it to drop the name of that sound card (which would cause problems for subsequent restarts if the card would come back). So, it will see a non-functioning sound card in that case.
PostPosted: Fri Sep 02, 2016 6:21 pm
ok Done...! working now!
PostPosted: Fri Sep 02, 2016 6:23 pm
Fixed:
- Edit: I see occasional jumps in the output VU meter. They are *not* present in the scope or in the sound card output. Will check.
- Stand alone HTML5 GUI FRIDAY
Windows stand alone: http://www.stereotool.com/download/ster ... 01-033.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-033.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-033.dll BUILD FAILED - NOT AVAILABLE
STEREO TOOL IMMEDIATE ATTENTION:
- Als saved en Load onder All Audio setting dan is Over Sampled Limiting and Clipping uit geschakeld -> Seems to work as designed (which is different from before though). -> Changed back for Stereo Tool
- Sync: Handle big difference between clocks. More than .01% is probably already too much. Then ignore. Add a parameter, set to 0.1%.
- Crash reported by Wouter Tietema, probably caused by low latency monitoring output. - probably fixed.
- Rename PNR to Dehummer?
- Crash with test tones -> Old beta (015), ignore.
IBC PREPARATION:
- Sound cards! Arrived! WEDNESDAY TO RAI 2x
- Check Axia mixer OK! GET WEDNESDAY
- USB sticks!!! ORDERED EXPECTED TUESDAY
- Call Karlex CALLED, WILL BE SHIPPED. EXPECTED TUESDAY
- Fancy name tags ORDERED
- FM analyzer! ORDERED CHECK STATUS
- Fast pc! ORDERED
- Business cards Matt ORDERED
- PC for Nautel - wait for reply Matt
- Images for booth presentations Mathijs TUESDAY
- Images for ST presentation TUESDAY
- Make full IBC setup SATURDAY SUNDAY
- FB post SUNDAY
- Email!
SST PREPARATION:
- Help page with power user markings. Some settings (sound cards) should not be marked.
- Myeasylog.log
- MicroMPX bug: -a "Card name" does not work! MONDAY Mathijs
- Run Valgrind for MicroMPX MONDAY Mathijs
- SST presets MONDAY
- Crash Leif?? (Maybe bad server data?)
STEREO TOOL RELEASE:
- Latency issue: Is it higher than before? And what to do with people who are updating? TUESDAY
- Add presets
- Release
- CHECK CRASH with VLC - VLC related??
- "This sound is processed by" in versions with different names. How to handle that?
OOK NOG:
- Update website
- Fill USB sticks THURSDAY
- 14 september speed date ideeenfabriek
DONE:
- Linux Fedora issue
- Make MAC version HELP work. (tonight) - to be tested
- Remove LQLL HQ mode (non-SST) (tonight)
- Check VMware flag turning ON for unknown reason (tonight) -> Not changed recently, and seems not to cause problems, so ignoring for now.
- Fixed synchronization problem between meters, scropes and audio
- INDEX.HTML automatisch resolven
- Add no cache to objects.js!!!
- Declipper broken according to DJ_DOGGY, so far unable to reproduce!
- Change version number
- Crash in BETA029 fixed.
- Linux Rivendell version -> Returns silence in FM output, why??? Add logging! --> _ST_AUDIO define! But why does it work in Windows?
- Kill License SST
- Remove warnings
- Check red output bars for 'Rules are there to be broken' - overshoots and clicks present.
- Make new separate Presets class ->
- Check and solve Linux Valgrind errors for Declipper
- Linux high CPU load
- Solved Low Latency mode crash
- Previous version could crash on startup. Should be solved now.
- White list IP's?
- Add Declipper main view
- Gain works again
- Type IP in web site
Later:
- Web interface export preset
- Generate UIDs and use link
- Password for login?
- Run as a service
- Websockets? Later
- Remove inputOldSamplesFixedCopy, should not be needed if I split WAVE from VU meter calculations.
PostPosted: Fri Sep 02, 2016 6:37 pm
Bug: The tooltip for "Continuous Release" shows the tooltip for "RMS block size".
