Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 127 28 29 30 3143 Next
PostPosted: Thu Sep 01, 2016 10:36 pm
Hans,
On dsp 031 the metersection behaves strange in comparison with 029.
With no input the meters show some activity.
Also clipbars appear higher, and the levelsmeter shoots for no reason
edit: strange behavior doesn't appear in 030 also
PostPosted: Thu Sep 01, 2016 11:22 pm
Hans,
I fixed a timing issue that was present in versions 030 and before. So, if you changed some settings synchronize the audio to what's shown in the graphs, it might behave differently now. (Current behavior *should* be the correct behavior, and as far as I've tested it is).
If this is not it, please send me your *full* settings ("EXPORT ALL") so I can check.
PostPosted: Thu Sep 01, 2016 11:50 pm
Does Stream Url on Input stop working ??? Is it broken or what??
I have link there and just test it on beta 31 - it works like it should.
I cant make it work..!
Works fine here too! What happens exactly? And does the same URL work fine in older versions/beta's? (please keep in mind that the beta's are 32 bit!)
PostPosted: Fri Sep 02, 2016 12:36 am
Hans,
minl801030- Med-2low freqChange_Z84.sts [101.68 KiB]
Downloaded 246 times
Hans, turn on Avanced Clipper, after red output, meter stays red, weird
PostPosted: Fri Sep 02, 2016 12:41 am
Ok the stream works but I see what you mean with the output. Will check what's wrong.
Edit: I see occasional jumps in the output VU meter. They are *not* present in the scope or in the sound card output. Will check.
PostPosted: Fri Sep 02, 2016 4:21 am
Not only are the VU output meter red overshoots FAR worse in beta 31, but a new problem has emerged:
The MB1 and MB2 meters (some combination of bands) will now periodically jump to full scale, for no reason. I'm testing with my own preset that I know very well. It never actually does that.
I tried to capture screenshots, but they happen so fast that it's practically impossible. In fact, I'm not even sure 30 fps video would capture it. Although VNC is responsive enough to see it.
I know this is purely a display issue, but the issue is beyond just the VU output meters.
PostPosted: Fri Sep 02, 2016 4:46 am
I see it on the advanced clipper meter too.
PostPosted: Fri Sep 02, 2016 6:29 am
Guys, you said it`s on DSP version - test it on Stand alone and tell Hans is it OK there , because not to confuse him and he again to mess them up . I`m saying it , because he just fix them in the Stand Alone and they work OK now.
Tell them if it`s only on DSP or not.
PostPosted: Fri Sep 02, 2016 6:30 am
DJ DOGGY - It's busted on standalone too.
PostPosted: Fri Sep 02, 2016 6:45 am
I don`t seethis here - looks like it appear if specific option is enabled .
On my side Advanced clipper is ON, Composite clipper is OFF , but don`t see such a problem
So try to start disable some options and look when or if the problem is gone - so Hans to can reproduce it more easy
