Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 126 27 28 29 3043 Next
PostPosted: Thu Sep 01, 2016 11:29 am
All meters above the scopes . All have a delay in response about 1.5-2 seconds - like that area of ST is working behind/after the scopes .
Scopes are OK.
Ah, turns out that some timing adjustment was broken - but not always, it depended also on I/O sample rates and whether FM was enabled. Fixed now. (Next beta).
PostPosted: Thu Sep 01, 2016 11:46 am
oh, i didn`t kno it was replaced by 30 in the last beta post. Alright will change it
Do you still have the Declipper issue in 030?
PostPosted: Thu Sep 01, 2016 1:19 pm
Yes, i still have it .
Watch this video to know what i do, to have the result from the audio you heard
http://www.filedropper.com/123_13
PostPosted: Thu Sep 01, 2016 2:05 pm
Ah. Reproduced it here. It happens if you have 'Ignore high frequencies' enabled, plus a latency of 2048 or 4096, plus non-phase linear HPF, plus Declipper. Turn any of those off and the problem is gone. Looking into it now.
PostPosted: Thu Sep 01, 2016 3:10 pm
That`s a good news - at least now i know it will be fixed
PostPosted: Thu Sep 01, 2016 3:49 pm
Fixed:
- Linux Fedora issue
- Make MAC version HELP work. (tonight) - to be tested
- Remove LQLL HQ mode (non-SST) (tonight)
- Check VMware flag turning ON for unknown reason (tonight) -> Not changed recently, and seems not to cause problems, so ignoring for now.
- Fixed synchronization problem between meters, scropes and audio
- INDEX.HTML automatisch resolven
- Add no cache to objects.js!!!
- Declipper broken according to DJ_DOGGY, so far unable to reproduce!
- Change version number
Windows stand alone: http://www.stereotool.com/download/ster ... 01-031.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-031.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-031.dll BUILD FAILED - NOT AVAILABLE
STEREO TOOL IMMEDIATE ATTENTION:
- Edit: I see occasional jumps in the output VU meter. They are *not* present in the scope or in the sound card output. Will check.
- Als saved en Load onder All Audio setting dan is Over Sampled Limiting and Clipping uit geschakeld
IBC PREPARATION:
- Sound cards! Arrived!
- Check Axia mixer OK!
- USB sticks!!! ORDERED
- Fancy name tags ORDERED
- FM analyzer! ORDERED
- Fast pc! ORDERED
- Business cards Matt ORDERED
- Call Karlex CALLED, WILL BE SHIPPED.
- Images for booth presentations Mathijs
- PC for Nautel FRIDAY
- Make full IBC setup
- FM post
SST PREPARATION:
- Stand alone HTML5 GUI FRIDAY
- Help page with power user markings.
- Run Valgrind for MicroMPX FRIDAY
- SST presets FRIDAY
- Crash Leif?? (Maybe bad server data?)
STEREO TOOL RELEASE:
- Latency issue: Is it higher than before? And what to do with people who are updating?
- Add presets
- Release
- CHECK CRASH with VLC - VLC related??
OOK NOG:
- 14 september speed date ideeenfabriek
DONE:
- Crash in BETA029 fixed.
- Linux Rivendell version -> Returns silence in FM output, why??? Add logging! --> _ST_AUDIO define! But why does it work in Windows?
- Kill License SST
- Remove warnings
- Check red output bars for 'Rules are there to be broken' - overshoots and clicks present.
- Make new separate Presets class ->
- Check and solve Linux Valgrind errors for Declipper
- Linux high CPU load
- Solved Low Latency mode crash
- Previous version could crash on startup. Should be solved now.
- White list IP's?
- Add Declipper main view
- Gain works again
- Type IP in web site
Later:
- Web interface export preset
- Generate UIDs and use link
- Password for login?
- Run as a service
- Websockets? Later
- Remove inputOldSamplesFixedCopy, should not be needed if I split WAVE from VU meter calculations.
PostPosted: Thu Sep 01, 2016 4:00 pm
Fast report:
beta31
Problem with Declipper or whatever it was, is fixed - iupii . Hm, i see like an improve in the sound at all after this fix - super
Problem with meters delay - fixed, works very good now.
Normal output (Input without processing) sound at higher speed + emptying buffer - still remains. I guess this will be fixed at the end , as a not that important problem
PostPosted: Thu Sep 01, 2016 6:47 pm
Does Stream Url on Input stop working ??? Is it broken or what??
PostPosted: Thu Sep 01, 2016 7:05 pm
I have link there and just test it on beta 31 - it works like it should.
PostPosted: Thu Sep 01, 2016 7:47 pm
I cant make it work..!
