Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 125 26 27 28 2959 Next
PostPosted: Thu Mar 17, 2016 8:01 pm
I think it is basically a good idea at the frayed edge to complete the sound. But I think there's great differences between the compression formats. MP2 has here, in my eyes the most artifacts. that is because the spectral resolution / subdivision is not very good. I think that particularly with mp3 a tough low-cut may not be particularly good, because here tiny details are still present in the higher frequencies. Can you somehow find out which type of compression the music was subjected to?
Yet another question: How do you rate the effort forth to improve the quality of voice on the phone? Can you recognize that it is language, and then add it here sibilance or similar?
PostPosted: Sun Mar 20, 2016 2:37 pm
Does anybody else notice an odd sounding edgy distortion when using the delossifier / spectral hole filler?
(Absolute highs are not active - noticed while playing audio from YouTube and switching on/off...)
PostPosted: Sun Mar 20, 2016 3:08 pm
It seems the "Voice Protection" setting of the classic multiband produces distortions (especially with piano instruments). The same settings sounds clear with Stereotool 7.03.
Here is a download of an example piano track:
http://ocremix.org/remix/OCR02928
The attached config produces distortions with 7.84, not with 7.03 - especially the loud part of the track beginning @ minute 3:16. The distortions dissappear when Voice Protection is set to zero.
viewtopic.php?f=14&t=7262&start=100#p33091
Still have the same problem with the current beta.
I illustrate it with this .WAV:
http://www.mediafire.com/download/4qdax ... _ReMix.zip
It contains the following clips: Original, processed with 7.03, processed with current beta, difference between both clips, processed with current beta without voice protection.
The difference clip shows the added distortions very clearly.
The tops seem to be "flatter" now in the current version (above current beta, below 7.03):
PostPosted: Sun Mar 20, 2016 6:32 pm
I'm guessing - not sure yet - that what you're hearing and what near05 is hearing is probably the same thing: Not so much the filling of holes, but the filling of the top area. I'll add a setting tomorrow that disables that, that way it still fills the holes but not the top part. That also means that it doesn't repair everything. but that can be the next step if this indeed fixes the issue.
(I haven't tried it on YouTube content yet, but I have noticed it on certain sounds in a 96 kbit/s MP3 file. There the cause was definitely the filling of the top area, which this filter was actually never designed for - Absolute Highs is, but that's a different filter!).
PostPosted: Sun Mar 20, 2016 9:09 pm
7.85 BETA044
Windows stand alone: http://www.stereotool.com/download/ster ... 85-044.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-044.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-044.dll
CHANGED:
I'm now considering a completely different reconstruction technique, which I want to try out tomorrow. But for now I expect (?) that the edgy distortion sound should be fixed by this.
- SPA remove monthly popup
- Added other optimizations
- Fix crash in BETA036.
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031 - Feedback so far is that it works fine
- Exciter: Try to reduce pre-ringing (maybe by doubling overlap? Or measure on bigger block size, then go back to smaller?)
- Exciter: Add auto-adjust HPF frequency
- MP3 sandy sound (caused by bad detection?)
- MP3 Propaganda - Duel way too much highs generated on default settings!
- License check
- set Encryption : impossible to view or modify all the processing settings
- Preset Licensing : encrypted preset without beeps unlocked by a license
- Resampler: Predict effect and compensate for that.
LATER:
- O skin
PostPosted: Sun Mar 20, 2016 10:29 pm
Anyone else having troubles with 7.85 BETA044
Windows defender say it's a virus
Categorie: Trojaans paard
Beschrijving: Dit programma is gevaarlijk en het voert opdrachten van een kwaadwillende gebruiker uit.
Aanbevolen actie: Deze software onmiddellijk verwijderen.
Items:
file:C:\Program Files (x86)\Stereo Tool\uninst.exe
uninstall:HKLM\SOFTWARE\Wow6432Node\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\Stereo Tool
regkey:HKLM\SOFTWARE\Wow6432Node\MICROSOFT\WINDOWS\CURRENTVERSION\UNINSTALL\Stereo Tool
PostPosted: Sun Mar 20, 2016 10:32 pm
I can't get it (the Winamp Version) to run, I keep getting EXCEPTION OCCURRED: IN Display Two: Got NAN input for gray.
This is not a serious problem but should never happen.
I get no audio.
PostPosted: Sun Mar 20, 2016 10:50 pm
I get no audio.
I have the same thing here, but if you unable the deflossifier main, then enable the spectral hole filler and the reconstruct top part then you can enable de deflossifier again. Then it works. :)
PostPosted: Mon Mar 21, 2016 1:57 am
Whoops, looks like I introduced a division by 0! For some reason it didn't happen on my end. I've fixed it, new version is building, will upload it tomorrow morning.
I've just added a new feature to my build script, it should automatically upload the new version as soon as the build is ready (probably about 30-60 minutes from now). So, you might be able to find them here, an hour from now:
Windows stand alone: http://www.stereotool.com/download/ster ... 85-045.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-045.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-045.dll
PostPosted: Mon Mar 21, 2016 11:16 am
Just ran a rather quick test using the latest beta. To my ear, turning off 'reconstruct top part' makes a big difference in reducing the distortion (as you suspected).
I do, however, still hear a crackly / edgy distortion when using the spectral hole filler. I'm testing using pretty poor quality YouTube material.
