Post new topic  Reply to topic  [ 286 posts ]  Go to page Previous 121 22 23 24 2529 Next
PostPosted: Fri Jun 04, 2010 1:29 am
Yes...
i did some settings, but with different settings in AGCs from suggested, to have stable voice in Celine's song..
Still i think that some precise settings in multiband is needed too. But from setting .00001 to .00002 there is lot space and . hmhm
If cannot be "ms", is it posible to be any number .. but visibly changed on keybord cursor.
Well .. and agc and multiband, Final limiter and loudness and all filters must work as one! Smart isn't it/
i found that few clicks on keybord (slider even is not moved) make some difference.
Anyway...
Hans and all, I would like to hear what you think ...
File comment: pic inside for agc settings
ST5_EL34_v2.rar [93.44 KiB]
Downloaded 333 times
PostPosted: Fri Jun 04, 2010 1:59 am
Yes...
Anyway...
ST5_EL34_v2.rar
I'll try to add more useful numbers tomorrow.
Is this file for the latest version (3A) or still for BETA? The AGC in 3A should work a lot better...
PostPosted: Fri Jun 04, 2010 2:05 am
beta3A
lol .. i again have bug with "meters"
PostPosted: Fri Jun 04, 2010 2:18 am
New version (Loudness issue fixed, no further changes):
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... ETA004.exe
Stand alone version: http://www.stereotool.com/download/ster ... ETA004.exe
VST version: http://www.stereotool.com/download/vst_ ... ETA004.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... ETA004.dll
Command line version: http://www.stereotool.com/download/ster ... ETA004.exe
The performance seems to be a few % worse than that of version 5.00, even if the 2nd AGC is turned off. I don't know yet what's causing this - most likely it's caused by a different memory layout due to the new and changed filters...
Edit: Without AGC, with low input volume, the performance is identical (for high input volume the Multiband fix starts to act up a bit). So I need to optimize the AGC to reach the same performance as before. If I only enable the AGC it's gotten about 20% slower then in v5.00.
By the way, I think that what I changed in the AGC would also make Multiband better...
PostPosted: Fri Jun 04, 2010 6:09 am
I updated some settings using the BETA004 posted above. I'm trying to avoid multiband at all costs in the algorithm. This is another shot at it - purely AGC and final compressor.
2AG2.zip [142.15 KiB]
Downloaded 347 times
PostPosted: Fri Jun 04, 2010 3:56 pm
Downloaded 8 times
That's honestly ......? I do not understand what you are doing ....... AGC need to manage the overall level of INPUT WHY THERE GATES? You simply PRESS with the signal from the input ... to reduce the noise between songs are noise gates !!!!!!!!!! Read carefully here is http://omniaaudio.com/manuals/6ex There is no and there was this!! Gates to AGC? I'm just shocked .......... Another matter to enter controlled frequency .... it was just great to read on page 68 omnia manuals.
PostPosted: Fri Jun 04, 2010 6:09 pm
Downloaded 8 times
And I'm just shocked about your false quote !
SuperH
and
hvz
are two different persons !
Good morning !
PostPosted: Fri Jun 04, 2010 7:05 pm
PostPosted: Fri Jun 04, 2010 7:15 pm
DUB<^>STEP>> HANS IF YOU GET THIS I JUST SENT YOU A DONATION 13 URO. ENJOY
PostPosted: Sat Jun 05, 2010 1:18 am
Thanks!
