Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 1201 202 203 204 205213 Next
PostPosted: Wed Oct 05, 2011 1:38 am
BETA127:
- Slight performance improvement. But it's so small I can hardly measure it (actually I'm measuring a slight decrease, but given the changes it HAS to be faster so that must be a measuring error). This does not seem the way to go to improve the performance further.
- VST version is building again (was missing in BETA126).
- Francis reported that the SSE version is working again, so I removed that issue from the todo list.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-127.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-127.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-127.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-127.dll
Command line version: http://www.stereotool.com/download/ster ... 20-127.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-127 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-127 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Fix Loudness display
- Smarter lows volume drop against highs protection: First clip using reduced highs (highs protection filter), then do it again but do NOT lower the lows below the level found in the 1st step. - NO! No longer needed.
- Optimize clipper code: Reflection, smaller overlap (stronger reflection possible?); optimize RMS search filter; optimize voice vibration removal
- HPF bad since BETA080, especially with declipper enabled
- Highs vs bass distortion protection: Fix window edges.
- Add highs distortion sensitivity slider(s)?
- AGC hangups
- DC caused by clipper
- Fix pre-ringing artifacts
- Checkbox to combine bands 1+2 of Multiband
- Phase linear highpass filter if non-phase-linear is selected to avoid DC offset.
- Strict bass clipping
- Channel swap in normal output: ASIO enabled and Use multiple CPU cores enabled - see viewtopic.php?f=14&t=3065&start=1861
- RDS: Filter out trailing spaces in word wrap mode
- Protection for vocals (Dutch pirate music)
- Remove or simplify 'Advanced highs protection', look at other protection mechanisms. Use smaller measurement intervals - allows lower 'maximum drop' values (hence has less impact on 'good' highs) and will catch more problematic transients. Add masking to ignore very brief drops.
- Save new clipper, bandpass, multiband options (STS+VST)
- Extra HPF step either just before Singleband or - if that's not used - after the bass protections for Loudness. Maybe also for phase linear HPF!
- Robot effect when changing to lower latency. Caused by Phase Rotation at lower Quality settings.
- Check performance, especially of Multiband.
- Update presets? (BASS_AGC etc.) 1 day BUSY
- Release 1 hour
- Add composite clipper
- Hiss in low latency output from high frequency content due to no lowpass filter - NOT NEW, and will be solved by redesign anyway.
PostPosted: Wed Oct 05, 2011 8:39 am
BETA127:
Preliminary and very informal testing shows no statistically meaningful change. I had to adjust settings to make the comparison "the same" (I prefer calling it "similar") due to the addition of the slider. I have also had crashes with Internet Explorer 8 and various wiki pages (not your issue, but...), so I probably need a restart, since Winamp uses IE for its' built-in browser, so there could be some memory funkiness going on.
Also, in other Winamp-related testing possibilities, I'm using the Bento skin, which, from what I gather, has the potential for using more CPU than some of the "classic" skins. This is kind of like how C and C++ will allow you to make serious errors (aka "provide you the noose to hang yourself"), but I may not have it configured to use a lot of CPU.
More to come...
Edit: You know, I've got this tickling in the cobweb-filled corner of my brain that you said you were looking into getting an i7 or you have an i7 AND that there was some support in the i7 to monitor the amount of cache used. I'm too much of a slacker right now (need to go to bed) to look further, but since you're in a time zone ahead of me, maybe you could check to see if I'm remembering correctly... ;)
PostPosted: Wed Oct 05, 2011 3:45 pm
Finishing up 6.20 now.
After that, when I'm finished at my current job I'll have lots of time to implement loads of new things, including a composite clipper. And I really want to add Stokkemask and BS-412 support. And a dynamics expander. And a new Multiband. And a new GUI.
I wonder. Will you redesign filters, meaning, will whole thing be capable to better support multicore cpu-s, so and threading...
Also one of main filters, Loudness, will it be splitted to 2-bads? Since it's much better/easier to control mix-outs (for e.g. protection) then in current workaround... etc
PostPosted: Wed Oct 05, 2011 4:51 pm
Hi Bojcha,
1. Yes I want to make more use of multiple cores. For the current declipper and clipper that should actually be really easy as they are both already calling the same code twice for each block of data, once for each channel.
For the clipper the drawback is that I won't be able to use multiple cores if I want to make a composite clipper.
About 2 bands for Loudness: Depending on what you mean, that's either not possible (at least not as far as I understand things. Lows, mids and highs each must be able to reach peak levels), or already implemented. I don't really see the current 'workaround' as you call it as a workaround - and as far as I could see on the Omnia 9 Leif is actually doing roughly the same things that I do. (Of course there might be things that are not visible).
If the multiband section does a better job though, with less bands, there will be less pressure on the clipper.
PostPosted: Wed Oct 05, 2011 8:30 pm
As far as I could see on the Omnia 9 Leif is actually doing roughly the same things that I do. (Of course there might be things that are not visible).
i'm not agree, totally.
Here is ST (with Loudness at almost end, to get some bass clip strict=10, stict clip bass to= -0.7dB)
Here's same sound-kick with bbp clipper only (static clip to ~-0.5)
With this i agree. But remember that Clipper for lows are in MB! That would be like you add "bass strict" to first two bands in MB and like that to go into loudness. And it's maybe to much to say that there is compressor between two.
PostPosted: Wed Oct 05, 2011 8:35 pm
My "spidey sense" tingling was correct, at least with respect to the performance monitoring capabilities of the i7:
http://software.intel.com/sites/product ... _guide.pdf
Perhaps some of that monitoring could tell you the level of L1 and L2 cache misses and other things. I think processors with an abundance of L3 are not all that negatively impacted, but if another memory I'm having about you (Hans) stating that you were noticing slowdowns on an i7, then L3 would also be something to monitor.
At this point, at least for AMD processors limited to 1MB of L2 cache, unless there is an AMD penalty going on, it may be as good as it's going to get without some low-level data that you might could glean from an i7, try to reduce the impact on i7, and then see if that translates down to older processors. As for the AMD penalty, you are using an old IPP library that when linked can cause the performance issues, even though your compiler itself is newer and supposedly no longer has the penalty.
PostPosted: Wed Oct 05, 2011 9:14 pm
@bojcha: is there a difference in sound? My clipped regions look wider, so I would expect the bass to be louder...
@Brian: which version of ipp has this penalty???
PostPosted: Wed Oct 05, 2011 9:24 pm
Yes ofcourse. As i said.. i needed to set loudness to ~x4 to get some clipping. Louder harmonics but too much bass itself.
If i set loudness less, there is almost no clipping (lows) meaning it's not louder.
for bbp only clipepr ON with 6dB threshold and scope shows exactly that, 6dB bass clip. and it still sound good.
PostPosted: Wed Oct 05, 2011 9:57 pm
The older version you're using, at least that's what my feeble brain is remembering. You said that SSE2 support was being dropped with newer versions and you hadn't found any advantage to using more than SSE2, so that, and some other reasons, were why you stuck with the older version of IPP. I checked into it at the time, which was some time ago, but I believe I confirmed that whatever version you have does have the dispatch issue. I think what I had figured at the time, which still could be wrong, as who knows what I have been thinking over the past several months (???), is that your version of the compiler is clean, but when you link the IPP code, the AMD performance hit can creep in that way.
If you list the versions of what you've got, I can try to reconfirm that (or you could)...
PostPosted: Wed Oct 05, 2011 10:30 pm
@Brian: I'm only linking the SSE2 version, the generic version is not even available in my library. I'm also not including the dispatcher......
The IPP version that I'm using is 6.1.2.041; compiler is 10.1. (Also not dispatching in the SSE2 version).
