Post new topic  Reply to topic  [ 26 posts ]  Go to page Previous 1 2 3
PostPosted: Thu Dec 03, 2009 4:36 pm
Could you tell me what you did exactly whit your friends windows xp computer to get an 192 khz output?
thanks in advance!
I just install that driver from MSI site... and i get that option to select 192kHz.
Is that the link you gave me in your earlier post? (http://download1.msi.com/files/download ... all_mb.zip) I've tried that one but here i haven't the 192 khz option, i have exactly the same realtek sound manager as my previous driver (the one from the driver disk from the motherboard)...
I've tried also the vista driver but i can't even do the setup. (maby of course because i use xp, but as you told i could try it). I've also tried the ALC889 driver, but gave me also the same sound manager screen whitout 192khz option...
Should i reinstall xp and then directly install that driver? (so the computer is "fresh agian" so it really has nothing in common with the old realtek driver)
Is your XP updated to the latest service pack? Early XP versions (I think up to service pack 2) did NOT support 192 kHz audio!
I use Windows Xp home edition Service Pack 3, legal en correctly activated version.
PostPosted: Wed Jan 20, 2010 11:03 pm
Check in bios for soundcard, HD-Audio mode or AC'97. If AC'97 put it to HD-Audio.
PostPosted: Tue Jan 26, 2010 10:24 pm
allright thank you,
soon i will try it
PostPosted: Thu Dec 16, 2010 12:19 am
MAn Just uninstall this shitty SP3
Make it SP2 ... i have ALC888 , it`s fully supported by SP2
WiN XP SP2 is old and classic . I know for what button is missing , change to SP2 and it will come !!!!
PostPosted: Tue Dec 21, 2010 1:47 am
Win7 ftw, its not like vista and it manages memory and other resources better than xp.
You'll get the 192k option even without installing the drivers from realtek's website.
http://imgur.com/XpLkm.png
PostPosted: Tue Jun 11, 2013 2:45 pm
I`ve never had a problem with my 888. XP SP2 , And just installed the Mb drivers for HD audio - done! Everything works like a charm . Every sample rate is changing from the software for the Motherboard. 888 is working with ST with no even little problem!
