After I changed the stepness to 64 db/oct like my preset has, bam, it happened again
So, thats how you can reproduce it at your end.
Now, if it helps you in any way, when I test this with the x64 version, it also throws some random error message at me as opposed to the 32 which just messes up the singleband.
Bingo - got it here as well now. In 32 bit, an invalid value is created which causes the SB compressor volume to be set to an invalid number - and there's no way it can recover from that.
In 64 bit, fortunately I get exceptions when this happens - so I can easily pinpoint where it goes wrong. Working on a fix now...
Edit: SOLVED. Will now also fix the weird sounds that occur when you change the MB bands (that has been on my list for a while already).
