Post new topic  Reply to topic  [ 154 posts ]  Go to page Previous 1 2 3 4 516 Next
 Post subject: Re: Stereo Tool 7.41
PostPosted: Mon Mar 03, 2014 6:33 pm
I had a problem I never had before with Stereotool: complete crash of Stereotool.
I have the same problems with the version. Adobe Audition CC crashes sometimes i use the VST Version. The error occurs only when stereotool works some minutes. i cannot reproduce it.
PostPosted: Mon Mar 03, 2014 8:14 pm
Windows restart --> start Stereotool, still crash of stereotool.
Uninstalled Stereotool + removed .ini file and its working again.
at first: Problem Event Name: AppHangB1 type: 6144
second: Problem Event Name: APPCRASH StackHash_f81a
Not sure if this a problem of my system?
Were you doing something when this happened or did it happen when you didn't touch it?? I suppose you didn't backup the ini file?
This is scary, I might have to roll back to version 7.40... :(
PostPosted: Mon Mar 03, 2014 8:52 pm
I just started windows --> stereotool--> see first problem.
then started stereotool again --> problem 2
restarted windows-- started stereotool --> problem 2
then I deleted everything en reinstalled everything.
I didn't make a copy of the .ini file.. Maybe it's in recycle bin but have to check that later
The Power of Sound
PostPosted: Mon Mar 03, 2014 9:20 pm
Strange .... nothing of this happened here , crashing or restarting or else.
I remember one time that Hans tell me why ST is crashing after update . It was something with the size of the window ? You are sure your size wasn`t too small ?
PostPosted: Mon Mar 03, 2014 9:26 pm
No Crashing probems here !
PostPosted: Mon Mar 03, 2014 9:36 pm
Yeah it's awkward.. It didn't happen before with this version. I just did the same as always... Therefore I don't know of its ST problem or a problem of my system.
The Power of Sound
PostPosted: Mon Mar 03, 2014 11:24 pm
Since i have installed 7.41-034 my system has also crashed a couple of times.
It only happens with start-up of ST standalone.
It crashes so badly, i even got a blue screen and had to restart the computer.
I do not always start up, sometimes someone else does, but whenever i had a crash, the ASIO output had hiccups, and said something like "restarted because of hangups..." over and over again until the crash.
But last sunday it runs 7 hours, with ASIO and Non-ASIO Outputs at the same time with no problems at all.
System is Windows 7 64 bit Intel quad-core and the only program that runs beside ST is SimpleCast and a title updater(manually).
E: Added some more info...
PostPosted: Mon Mar 03, 2014 11:41 pm
So you still run the developement version 7.41-034 ?
Because in the release 7.41 Asio and Non-Asio does not seem to work on my system.
Just to make sure it's not my system causing the problems.
PostPosted: Tue Mar 04, 2014 12:09 am
I think i do, but to be sure i will check tomorrow after work.
So i'm running a development version... I didn't know that :D :D
Maybe thats why my system crashes...
I will update tomorrow after 18:00.
Goodnight.
PostPosted: Tue Mar 04, 2014 5:10 am
Hm, interesting stuff.
@Studio 11:
There is actually someone else who had issues when using ASIO (whole pc was stuck after 1-3 days, so similar to your blue screens) in 7.40, but apparently (so far) NOT with version 7.41.
The thing here is, nothing that I can do in software should be able to cause a blue screen. The only reasons for BSOD's are: Hardware malfunction, Windows bug of driver bug. I did rewrite the ASIO stuff, which might change the behavior (mainly timing) - which could trigger a bug in a driver. Which sound card do you have?
To rule out a hardware error that occurred just at the moment that you installed this new version, can you try version 7.40 again?
@PowerSound: You started version 7.41, and you had already ran it before without issues? And then suddenly when you started it it didn't work?
I Googled the errors that you mentioned, found this (does not seem to be related to Stereo Tool AT ALL, but that doesn't explain why reinstalling Stereo Tool (only Stereo Tool, right???) fixes it.
Notice: AppHangB1 problems occur when important operating system files become misconfigured, deleted or damaged. This is a common problem with computers that don't get maintained regularly. Eventually the system becomes overloaded with problems and begins to crash and display errors.
Elsewhere I read that this can happen when you close the system down incorrectly.
Info that I found about the other error (StackHash) doesn't seem to make any sense.
You might want to run a virus & spyware scanner...
@DJ-DOGGY: That was when I introduced the new GUI (6.32 -> 7.00). Not relevant now.
near05: This is only with the latest version? And does it crash when you close it, or during processing, or something else?
