 Post subject: Re: Euphoria!
PostPosted: Sun Jul 08, 2012 4:34 pm
- Advanced Bass and Advanced Extreme Highs-Protection are switched off (causes the audio to stutter).
- Highs Volume Drop Protection is switched off as well - causes the server to hang
- Bass boost: Switched off, because I don't like it
You can turn off all that, Bass boost also, all is adjusted if bass is too much jus tto turn off "bass boost".
Only thing you should never turn off is "Advanced bass distortion protection" !
What is the Noise Gate good for in this scenario?
Noise gate is adjusted to remove very soft noise from some tracks. It's usefull since AGC and Multiband has big range and knows to amplify audio much. Should be good for many tracks, and not too much to kill some soft highs in process.
Pre-Emphasis for Lossy Compression: Can you explain, what exactly that does?
Pre-emhasis (for normal output - 0-30us) is good to remove peeks on highs. So you can push more overall peek level.
For same reason (and decoding/encoding reason) you must set post-amp lower to avoid clipping.
For mp3 stream enough should be ~-1.2dB
For AAC streams ~2.5
Check this picture: http://www.stereotool.com/images/mp3_sp ... ection.png
PostPosted: Thu Jul 12, 2012 11:15 am
Okay, turned that on again.
Since we play quite a few lo-fi tracks, I switched that filter off. If there is any white noise, etc. on the original recording, I like to keep it.
Now I got it! :)
Thanks again,
Mike
PostPosted: Fri Jul 13, 2012 1:30 pm
very good preset, thank you bojcha , i use it for my private webradio ;)
www.radiopop.fr.st
PostPosted: Fri Jul 13, 2012 2:53 pm
I still need to fix some things, mostly in multiband. Actually problem is band 3. It's not counted in "voice protection" so i must add another band between band1 and band2 and adapt all. :|
PostPosted: Sat Jul 14, 2012 2:58 pm
...well, I wonder how you will solve that ;)
PostPosted: Mon Jul 16, 2012 6:56 pm
Thnx Bojcha!
It's really amazing preset. I've upload an mp3 test, recorded from fm tuner, through mpx output of StereoTool.
Very satisfied :) Hear it yourself:
http://www.sendspace.com/file/9y1wjc
PostPosted: Tue Jul 17, 2012 12:07 am
thanks...
I still need to make FM version when i finish standard version! I guess it should be even better.
PostPosted: Sat Jul 21, 2012 3:13 pm
The latest RC sounds really good with Stereo Tools latest beta. I wonder how you could ever improve this... ;)
Cheers,
Mike
PostPosted: Sat Jul 21, 2012 4:40 pm
I don't need ..i am at about v46 of preset.. and new beta is out which gives me chance to define what bands will be in "vocal protection".
Already checked, default is 4-7 and for EU4ria bands i would need 3-6 :)
PostPosted: Fri Jul 27, 2012 12:33 pm
Go for it! Cant't wait... :D
