Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2 3
 Post subject: Re: Unreal Engine 3 FM
PostPosted: Thu Oct 11, 2018 9:28 pm
Have any effect the "Multipath Stereo Phase Difference Remover" enabled in the HD version? :D
https://fmfeeling.com
PostPosted: Thu Oct 11, 2018 9:42 pm
Yes.
PostPosted: Thu Oct 11, 2018 11:45 pm
HD version uploaded.
Hi Bojcha, Where can we download the HD version of Unreal Engine 3?
PostPosted: Fri Oct 12, 2018 1:27 am
1st post.
PostPosted: Tue Feb 25, 2020 9:05 pm
UnrealEngine3_FM_final.stsUnreal Engine 3 FM!
first beta:
UnrealEngine3_v0.14.FM.sts
New goal to this new preset is to make it slightly louder (if possible 8dBr) then UE2. Also bit to tame high end compared to UE2 and generally make warmer but bit louder. Also big goal is to make MB to do as much as possible job in leveling yet to do much compression too without going to fatigue problem.
UE3 v.0.22 FM
UnrealEngine3_v0.22.FM.sts
Changed a lot of things in 0.22:
- Bass is much changed
- compression even more do leveling (Auto EQ do not need to do much job now - but still there)
- De-Modulated Level is limited to 125-135% to avoid composite clipper to make some distortions to highs
- eq
- bit faster AGC
- etc
UE3_v0.26
Unreal Engine 3 v0.29 RC1
UnrealEngine3_FM_v0.29_RC1.sts
- At end i decided to remove all non-phase-linear filters
- Tuned from average +8dBr to around +7.5
- More natural sprectral and final level
- other small tings
- wrong stereo settings in this version. Will be fixed in next.
Unreal Engine 3 FM Final
Also Final version of preset is in StereoTool v9.10!
Unreal Engine 3 HDUnrealEngine3_HD_final.sts
love this setting ... how impactful will it be is I turn off the auto eq ....
PostPosted: Wed Jul 01, 2020 1:47 pm
This has grown to be my favourite codec, it provides a strong sound while also being stable across the many genres and styles I use.
It does have difficulties on some alternative music with the vocals feeling lost in the mix a bit, which I guess in part is because these songs don't follow the conventional "rules" of pop production and thus the preset isn't enhancing those frequencies. I guess it's wishful thinking that one day a preset might be made that's better suited to that music.
PostPosted: Thu Jul 02, 2020 12:02 am
Have just found the HD version of this present - it's fantastic! Truly transparent - you don't notice it working.
