Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 492 posts ]  Go to page Previous 118 19 20 21 2250 Next
PostPosted: Thu Jul 28, 2022 5:34 pm
32-bit VST crashes in Reaper and BreakawayOne. Haven't tested 64 bit.
Something appears to have gone wrong with today's build, I'll run a new one tonight.
PostPosted: Thu Jul 28, 2022 7:18 pm
Also RadioBoss wouldn't load the 64 bit vst2 version either.
PostPosted: Fri Jul 29, 2022 11:39 am
BETA030 is available, VST's should work now.
PostPosted: Fri Jul 29, 2022 2:54 pm
b30, VST2 32, Reaper and BreakawayOne
enabling Fullscreen Mode breaks UI functionality. In Reaper the UI stops accepting clicks. In BreakawayOne, the plugin window turns white.
PostPosted: Fri Jul 29, 2022 3:40 pm
Ah, we need to disable that. Fullscreen mode makes very little sense in a VST window.
PostPosted: Fri Jul 29, 2022 3:48 pm
I would agree if, in Breakaway One, it didn't help fill out the window if it gets resized. The old GUI relied on this workaround as well. I have a key combo to resize a window to 75% of the monitor, and it leaves extra white space when applying it to the ST VST window in BA1.
PostPosted: Sat Jul 30, 2022 12:17 am
Hello. The web interface won't start even on the vst2 version.
PostPosted: Sat Jul 30, 2022 2:40 am
Oops! The issue wasn't what I wrote before. Instead, what was happening was that the VST and Winamp plugins were both built without the new web interface included. But because the new GUI is included, they default to the new web interface - which isn't there. And because of that it didn't return anything.
Fixed in the next beta.
PostPosted: Thu Aug 04, 2022 1:40 am
Stand-alone Win 10 x64 b31
On my primary monitor at 200% DPI scaling, the space for the numbers in the meter bar shrinks making them eventually disappear. It's fine on my secondary monitor at 100% DPI (the window is at 75% scaling).
PostPosted: Thu Aug 04, 2022 7:48 am
Oof, this could be a big one... Will look into it. Thanks for sharing!
I can already see that it's not fine. The spacing seems way larger than it should be...
