Post new topic  Reply to topic  [ 183 posts ]  Go to page Previous 115 16 17 18 19 Next
PostPosted: Fri Jun 27, 2014 4:39 pm
Oooopppppssss
Sorry I haven't read the help page.
Another thing that i want to ask. Is it possible to stream mpx ???
Thanks for your very fast response.
Kostas...
My radio station
http://amradio.ddns.net
PostPosted: Fri Jun 27, 2014 4:45 pm
I've read the help page couldn't find anything about icecast.
Is it posible to connect to icecast as well.
Sorry for my newbiew questions..
Edit: Test stream with vlc http://amradio.noip.me:8080/
My radio station
PostPosted: Fri Jun 27, 2014 9:07 pm
Where is the AM output level slider? I'm using a version from a beta or two ago in case it has changed.
PostPosted: Sat Jun 28, 2014 2:51 am
You probably would not want to encode/transform and "stream" it like standard audio.
You would best look at encapsulating it in the same manner as AoIP and thus will allow you to route the service across any IP capable network you have access to.
While you could do this in something like Stereo Tool, you would still need an appropriate receiver package at the other end to reassemble and output in MPX.
Would be an interesting concept though! :-)
Rossco
PostPosted: Sat Jun 28, 2014 4:56 am
Oooopppppssss
Kostas...
This equipment allows this:
http://www.solidynepro.com/indexahtmlp_ADA102ENG,t.htm (Version ADA102mpx)
this is a streaming encoder flac to 192 KHz.
I'm sure this could be achieved by software also.
PostPosted: Sat Jun 28, 2014 9:10 am
Rossco
I am intrested in that because alot of stations will have a internet feed to the transmiter side and usually proccess it in a dedicated high end copmuter in the transmiting site. By streaming MPX you can safelly controle and maintain this high end computer in the studio and stream out to multiple transmiter site. This could mean sync issues but it yould be perfect for most stations here in Rhodes,Greece . Here we don't have big, air-conditioned and most importantly DRY building in trasnmiter site so computers can run for aproxometly one year.
Kostas
My radio station
PostPosted: Sat Jun 28, 2014 9:13 am
Oooopppppssss
Kostas...
That's intersting so if we encode 192Khz in a non lossy compression (like mp3) we can send mpx .
Thanks very much ... Experament time now...
Kostas
My radio station
PostPosted: Sat Jun 28, 2014 10:11 am
Kostas
lol, sure not mp3. And sure not with ST. Other side need proper "receiver" And sure not to multiple transmitters since that would mean need of "multicast" - if we want low latency and proper codec/buffer/jitter/ handling.
PostPosted: Sat Jun 28, 2014 10:49 am
VLC uses IceCast - so that's supported. To see all the supported formats, read the VLC documentation - a lot is possible!
PostPosted: Sat Jun 28, 2014 10:50 am
Oooopppppssss
Kostas...
Of course it can, the problem is that you need to find something that can generate a signal that's formatted such that this device can decode it. And if it uses its own format that will be difficult...
