7.85 BETA030
Windows stand alone:
http://www.stereotool.com/download/ster ... 85-030.exe
Winamp DSP:
http://www.stereotool.com/download/dsp_ ... 85-030.exe
Windows VST 32 bit:
http://www.stereotool.com/download/vst_ ... 85-030.dll
Absolute Highs seems to be nearly finished now! Please set the "Pass squeeks" setting to 100% (default is 200%!). I kinda forgot to remove it, it's now determined automatically and the slider shouldn't be needed anymore (but setting it about 100% will still cause squeeky sounds).
CHANGED:
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Exciter: Add Volume slider
- Exciter: Add DIFF mode
- Voice protection in classic MB is broken. Check what changed. (Code should not have changed at all). - Hm, more has changed. Check in which version! -> Waiting for reply to question
- MB: Make Overview window for new Multiband! For main settings.
- MB: Add voice volume protection, don't allow mid bands to drop below surrounding (to some extent), protectes voices and it might help to replicate the sound of certain other processors
- Exciter: Make 2 kHz block size configurable, or automatic, or combination. Might work best if it's constant??
- Exciter: Add auto-adjust frequency
- Exciter: Improve further, and make it configurable.
- Add Polar stereo
viewtopic.php?f=16&t=6233&p=33031#p33031
- MP3?
- O skin
