Post new topic  Reply to topic  [ 424 posts ]  Go to page Previous 114 15 16 17 1843 Next
PostPosted: Tue Aug 02, 2016 9:03 pm
Is the window missing in AGC?
Not implemented yet, I guess.
That's where we need it the most.
PostPosted: Wed Aug 03, 2016 12:31 am
I know! But the AGC code is very messy and I really need to redesign it from scratch.. for the compressors it was easy to add it, for the AGC it's a bit less easy. Although, since it could be a quick win, maybe I should do it anyway (I was actually planning to not touch it until I would start the redesign).
PostPosted: Wed Aug 03, 2016 12:32 am
TODO: Add exception if ignoring too high VST parameter numbers (Audacity bug! -> Was fixed in later Audacity version, never mind).
in which audacity version was this fixed?
I don't know, the person who reported this said that he updated to the latest version (which in its list of changes contained a lot of VST things) and that fixed the problem. So, if you update to the latest version it should be ok. (Beside that, I'm checking for it in my code as well so it won't cause a crash anymore).
PostPosted: Wed Aug 03, 2016 12:34 am
I beg of thee, do it now. Don't wait for the redesign.
PostPosted: Wed Aug 03, 2016 10:06 am
Windows stand alone: http://www.stereotool.com/download/ster ... 01-018.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-018.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-018.dll
Known issues:
- Quality between 100 and 150%?
- Websockets?
- Generate UIDs and use link
- Password for login?
DONE:
- Gain works again
- Type IP in web site
Later:
- Run as a service
PostPosted: Wed Aug 03, 2016 11:36 am
Beta 018
I do this quick in dutch!
Hans, het probleem met de output meter is opgelost in beta 018. Maar de output audio waveform doet het niet maar voert wel gewoon signaal door.
PostPosted: Wed Aug 03, 2016 11:45 am
@Daniel: Ja kwam er ook net achter. Ga ik fixen!
PostPosted: Wed Aug 03, 2016 12:48 pm
Top!
PostPosted: Wed Aug 03, 2016 6:10 pm
after you wrote this information i take a look at the audacity homepage. and you are right. there is a hidden subpage where you can download nightly builds of audacity, like your beta versions.
http://gaclrecords.org.uk/win-nightly/
i tried the latest version, and it worked! thats really great. but unfortunately there is a maybe a new bug. the output waveform is not displayed. it's always black.
PostPosted: Thu Aug 04, 2016 2:38 am
Fixed:
Windows stand alone: http://www.stereotool.com/download/ster ... 01-019.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 01-019.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 01-019.dll
Known issues:
- Hiccup when switching presets
- Quality between 100 and 150%? DONE, 100-110 is not great, rest is.
DONE:
- Gain works again
Later:
- Run as a service
- Websockets? Later
