Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 114 15 16 17 1859 Next
PostPosted: Mon Feb 08, 2016 11:18 am
I've just ran a test and there are more differences in sound between version 7.84 and 7.03. I have done a lot of optimizations (so it's not easy to compare the code), but I'll take a quick look at it on Monday (it's easier in my office with 2 monitors to compare the code and the behavior of the two versions).
Thanks for looking into it. I use Stereotool almost every week to remaster tracks for my private colection or for my mixes ( https://www.mixcloud.com/LDASTA/ ). Besides the web browser its probably the most used software on my computer for the last couple of years. :)
Ok, I've checked what's happening. Now there are 2 things and I need to know which of the two you hear!
1. The singleband compressor for some reason creates a crackle at some places. It happens in a few spots in the track that you sent me, and the crackles are very brief. I can't really say that I hear them, but I see them in the spectrum (they are kinda masked by the onset of the piano tone).
2. There is some vibrating effect if I subtract the outputs. It's very soft compared to the total level, but it's constantly present. It's also present without voice protection, but it gets a bit worse when I enable it. I will check now (I have an idea) if I can find the cause.
3. Finally there's a crackle at startup. -> Ow, seems to be caused by bandpass filter. Hm... Checking now... --> Solved, was caused by Ignore high frequencies
PostPosted: Tue Feb 09, 2016 1:25 am
7.85 BETA027
Windows stand alone: http://www.stereotool.com/download/ster ... 85-027.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-027.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-027.dll
Main change is that I added K filter for Polar Stereo for OIRT FM band.
CHANGED:
- Fixed crash when closing
- GUI: Added tooltips!
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Voice protection in classic MB is broken. Check what changed. (Code should not have changed at all). - Hm, more has changed. Check in which version! -> Waiting for reply to question
- MB: Make Overview window for new Multiband! For main settings.
- Exciter: Improve further, and make it configurable.
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- MP3?
- O skin
PostPosted: Tue Feb 09, 2016 4:25 am
I think, its probably more towards the second effect. To me it just sounds like slight clipping/overcompression distortions (which you might mean with vibrating effect).
PostPosted: Tue Feb 09, 2016 12:00 pm
this question
What do you mean what polar stereo how it works, what benefits have a sound working ?
This latest beta, crashes when you change the Latency Samples to 4096!
Sexy Girls in your city
PostPosted: Tue Feb 09, 2016 12:26 pm
Same here!
PostPosted: Tue Feb 09, 2016 2:04 pm
No crash here, but there was something wrong with Hard Limit in the last beta, so that might be causing it.
PostPosted: Tue Feb 09, 2016 3:05 pm
I have a little bug found:
By enableling Tooltips (Show Tooltips), the Tooltip Processing --> Absolute Highs does not work.
In 7.85 Beta 25 the Absolute Highs Tooltip is shown and works correctly.
PostPosted: Tue Feb 09, 2016 3:20 pm
I haven't written the help text for it yet. Now I'm just wondering what it can have shown in BETA025....
PostPosted: Tue Feb 09, 2016 3:34 pm
Hans don't worry,
It was my mistake. In 7.85 Beta 25 the Mouse Pointer was over Multiband 2
