Post new topic  Reply to topic  [ 162 posts ]  Go to page Previous 113 14 15 16 17 Next
PostPosted: Fri Aug 27, 2021 1:09 pm
Bug fix: True Bass levels were calculated incorrectly if certain filters were placed after it. This caused some presets to have more bass than they originally had. Added a "Legacy" setting to choose between old and new behavior.
Interesting. I'll mess around with this. I generally put it near the end of the chain myself.
PostPosted: Fri Aug 27, 2021 9:09 pm
I just compared my 7 band multiband only (1 thread) it uses 9,1% CPU, and without "Dynamic Speed" it uses 3.9% CPU (again reported by ST). So almost 2/3 of multiband CPU usage is used by that filter only. Both are same peek mode jsut this thing On and off.
Checked, Wasapi broken on input.
Ok i now also compared SymmetricRMS mode in multiband. Whole MB is 18% Cpu Usage, and without "Dynamic Speed" is 6.8% so pretty much same difference as in peek mode. Actually bit worse diff then in peek mode plus overall more cpu usage.
PostPosted: Sun Aug 29, 2021 12:14 pm
Higher CPU load than peak? Do you by any chance have the "Heavy CPU (Compatibility)" option enabled? That increases the CPU usage of RMS mode by a factor 3 or 4 I think. It has no effect on Peak mode.
PostPosted: Sun Aug 29, 2021 12:19 pm
Release post: viewtopic.php?f=14&t=31003
Note: I can't change the version number that's shown on the old site anymore, due to a CMS issue. But it's version 9.80, not 9.70 as the page says.
PostPosted: Sun Aug 29, 2021 2:41 pm
Thanks for the new version!
Where can I see the current version number then? The new site doesn't seem to show it at all. Only in the version history?
PostPosted: Sun Aug 29, 2021 4:42 pm
hmm Yes. and it's by factor 6. 18.3% vs 3.1 with DS on. 1.6% without DS. Difference in audio is huge tho.
PostPosted: Sun Aug 29, 2021 5:00 pm
Oh. I'll look into that. It shouldn't be. "Heavy CPU" was there because there's a bit of difference in the behavior, but it should be possible to make both sound the same (maybe with some small changes in settings).
PostPosted: Sun Aug 29, 2021 5:01 pm
The new site isn't officially live yet, but it's almost... I noticed this too and will fix it.
PostPosted: Sun Aug 29, 2021 8:51 pm
How's input2 going? I am so much interested in fix, so i can actually set backup on every transmitter where i recently set ST.
PostPosted: Mon Aug 30, 2021 3:55 am
is 9.70 beta version 46 the same as the released version 9.80 on the new website ?
