Post new topic  Reply to topic  [ 190 posts ]  Go to page Previous 113 14 15 16 1719 Next
PostPosted: Sun Jun 30, 2013 6:45 am
BETA724-023:
Stand alone: http://www.stereotool.com/download/ster ... 24-023.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 24-023.exe
VST: http://www.stereotool.com/download/vst_ ... 24-023.dll
Linux CMD: http://www.stereotool.com/download/ster ... ETA724-023
Linux Standalone: http://www.stereotool.com/download/ster ... ETA724-023
Windows: Synchronize fixed
Windows: Fixed some small issues introduced in previous beta's.
Linux: Close fixed
Linux: Logging added when processing audio (for AlexL). Shows '.' every so many audio blocks.
PostPosted: Sun Jun 30, 2013 7:45 am
Before I move to 64 bits I really want to get this version stable. And release it (both Windows and Linux).
That would also seem to be an ideal time to ensure that you are able to build with the latest compiler and IPP libraries.
Do you agree?
I will definitely compare the 64 bit performance of the two.
That wasn't the response I was hoping to generate, although I did try to be less direct / forceful than normal.
What I meant was that a significant effort was put forth to make the latest compiler / IPP versions be at or near the same performance level of 10.1 / 6.x. From what I remember, at last this was discussed, you knew why the remaining code didn't vectorize. I think I just dropped talking about it then, so I don't know if the "Performance Degradation" thread over on the Intel forum is still applicable or not.
Whatever the case, you can't stick to 10.1 / 6.1 indefinitely. You lose any improvements and security fixes.
Further, while I am very hopeful about having funding to actually get a new system, I could be stuck on this 32-bit platform for a while longer. In addition, I believe Bojcha is pretty set on using 32-bit XP, as are probably quite a few other people due to driver support for 64-bit still being lacking in some areas.
I know trying to figure out why the performance went down isn't "sexy", nor does it immediately generate money, but it is still something that needs to be done. This is one aspect of self-employment that, in my opinion, clouds judgement, and not just for you, but likely for me as well if I were in the situation. Working on features is generally a guaranteed revenue source, but working on something like figuring out what needs to be done to make the code effecient on a newer compiler is probably all cost. If a person is not self-employed, there is still money coming in, but not if self-employed. Still, it needs to be done.
PostPosted: Sun Jun 30, 2013 11:52 am
Oh oh, there must be a fatal error in the new linux-beta (or I'm doing something wrong).
When I start ST the first time, everything is normal and works. Then, I close ST by clicking the X or closing the terminal. Then, I start ST again - the GUI appears shortly on the screen, but then crashes very quickly and puts out this in the terminal:
jack_client_new: deprecated
Stereo Tool
Activating Jack c481a58
Jack connection opened
.*** glibc detected *** stereo_tool_beta: double free or corruption (!prev): 0x0dd985d8 ***
======= Backtrace: =========
/lib/i386-linux-gnu/libc.so.6(+0x75ee2)[0xb6b84ee2]
/usr/lib/i386-linux-gnu/libstdc++.so.6(_ZdlPv+0x1f)[0xb6d9b51f]
/usr/lib/i386-linux-gnu/libstdc++.so.6(_ZdaPv+0x1b)[0xb6d9b57b]
stereo_tool_beta[0x8078a04]
stereo_tool_beta[0x8076c32]
/lib/i386-linux-gnu/libpthread.so.0(+0x6d4c)[0xb6cbfd4c]
/lib/i386-linux-gnu/libc.so.6(clone+0x5e)[0xb6bfddde]
======= Memory map: ========
08048000-087b3000 r-xp 00000000 08:06 1451061    /usr/local/bin/stereo_tool_beta
087b3000-087b4000 r-xp 0076a000 08:06 1451061    /usr/local/bin/stereo_tool_beta
087b4000-087de000 rwxp 0076b000 08:06 1451061    /usr/local/bin/stereo_tool_beta
087de000-0abce000 rwxp 00000000 00:00 0
0c474000-0ddd9000 rwxp 00000000 00:00 0          [heap]
8fa47000-8fa48000 ---p 00000000 00:00 0
8fa48000-90800000 rwxp 00000000 00:00 0
90800000-90850000 rwxp 00000000 00:00 0
90850000-90900000 ---p 00000000 00:00 0
90990000-90afe000 rwxp 00000000 00:00 0
90afe000-90aff000 ---p 00000000 00:00 0
90aff000-912ff000 rwxp 00000000 00:00 0
912ff000-91300000 ---p 00000000 00:00 0
91300000-91b00000 rwxp 00000000 00:00 0
91b00000-91b29000 rwxp 00000000 00:00 0
91b29000-91c00000 ---p 00000000 00:00 0
91c21000-91c22000 ---p 00000000 00:00 0
91c22000-92422000 rwxp 00000000 00:00 0
92422000-92423000 ---p 00000000 00:00 0
92423000-92c23000 rwxp 00000000 00:00 0
92c23000-92c83000 rwxs 00000000 00:04 589837     /SYSV00000000 (deleted)
92c83000-92c84000 ---p 00000000 00:00 0
92c84000-936dd000 rwxp 00000000 00:00 0
936dd000-936de000 ---p 00000000 00:00 0
936de000-93ede000 rwxp 00000000 00:00 0
93ede000-93edf000 ---p 00000000 00:00 0
93edf000-946df000 rwxp 00000000 00:00 0
946df000-946e0000 ---p 00000000 00:00 0
946e0000-94ee0000 rwxp 00000000 00:00 0
94ee0000-94ee1000 ---p 00000000 00:00 0
94ee1000-956e1000 rwxp 00000000 00:00 0
956e1000-956e2000 ---p 00000000 00:00 0
956e2000-95ee2000 rwxp 00000000 00:00 0
95ee2000-95ee3000 ---p 00000000 00:00 0
95ee3000-966e3000 rwxp 00000000 00:00 0
966e3000-966e4000 ---p 00000000 00:00 0
966e4000-98db6000 rwxp 00000000 00:00 0
98db6000-98db7000 ---p 00000000 00:00 0
98db7000-995b7000 rwxp 00000000 00:00 0
995b7000-995b8000 ---p 00000000 00:00 0
995b8000-99db8000 rwxp 00000000 00:00 0
99db8000-99db9000 ---p 00000000 00:00 0
99db9000-9a5b9000 rwxp 00000000 00:00 0
9a5b9000-9a5ba000 ---p 00000000 00:00 0
9a5ba000-9adba000 rwxp 00000000 00:00 0
9adba000-9adbb000 ---p 00000000 00:00 0
9adbb000-9b5bb000 rwxp 00000000 00:00 0
9b5bb000-9b5bc000 ---p 00000000 00:00 0
9b5bc000-9bdbc000 rwxp 00000000 00:00 0
9bdbc000-9bdbd000 ---p 00000000 00:00 0
9bdbd000-9c5bd000 rwxp 00000000 00:00 0
9c5bd000-9c5be000 ---p 00000000 00:00 0
9c5be000-9f27e000 rwxp 00000000 00:00 0
9f27e000-9f27f000 ---p 00000000 00:00 0
9f27f000-9fa7f000 rwxp 00000000 00:00 0
9fa7f000-9fa80000 ---p 00000000 00:00 0
9fa80000-a0280000 rwxp 00000000 00:00 0
a0280000-a0281000 ---p 00000000 00:00 0
a0281000-a0a81000 rwxp 00000000 00:00 0
a0a81000-a0a82000 ---p 00000000 00:00 0
a0a82000-a1282000 rwxp 00000000 00:00 0
a1282000-a1283000 ---p 00000000 00:00 0
a1283000-a1a83000 rwxp 00000000 00:00 0
a1a83000-a1a84000 ---p 00000000 00:00 0
a1a84000-a2284000 rwxp 00000000 00:00 0
a2284000-a2285000 ---p 00000000 00:00 0
a2285000-a4fff000 rwxp 00000000 00:00 0
a4fff000-a5000000 ---p 00000000 00:00 0
a5000000-a5800000 rwxp 00000000 00:00 0
a5800000-a5801000 ---p 00000000 00:00 0
a5801000-a6001000 rwxp 00000000 00:00 0
a6001000-a6002000 ---p 00000000 00:00 0
a6002000-a6802000 rwxp 00000000 00:00 0
a6802000-a6803000 ---p 00000000 00:00 0
a6803000-a7003000 rwxp 00000000 00:00 0
a7003000-a7004000 ---p 00000000 00:00 0
a7004000-a7804000 rwxp 00000000 00:00 0
a7804000-a7805000 ---p 00000000 00:00 0
a7805000-a8005000 rwxp 00000000 00:00 0
a8005000-a8006000 ---p 00000000 00:00 0
a8006000-a8903000 rwxp 00000000 00:00 0
a8903000-a8904000 ---p 00000000 00:00 0
a8904000-aa4bb000 rwxp 00000000 00:00 0
aa4bb000-aa4bc000 ---p 00000000 00:00 0
aa4bc000-aacbc000 rwxp 00000000 00:00 0
aacbc000-aacbd000 ---p 00000000 00:00 0
aacbd000-ab4bd000 rwxp 00000000 00:00 0
ab4bd000-ab4be000 ---p 00000000 00:00 0
ab4be000-abcbe000 rwxp 00000000 00:00 0
abcbe000-abcbf000 ---p 00000000 00:00 0
abcbf000-ac4bf000 rwxp 00000000 00:00 0
ac4bf000-ac4c0000 ---p 00000000 00:00 0
ac4c0000-accc0000 rwxp 00000000 00:00 0
accc0000-accc1000 ---p 00000000 00:00 0
accc1000-ad4c1000 rwxp 00000000 00:00 0
ad4c1000-ad4c2000 ---p 00000000 00:00 0
ad4c2000-adcc2000 rwxp 00000000 00:00 0
adcc2000-adcc3000 ---p 00000000 00:00 0
adcc3000-b0300000 rwxp 00000000 00:00 0
b0300000-b03d8000 rwxp 00000000 00:00 0
b03d8000-b0400000 ---p 00000000 00:00 0
b040e000-b0413000 r-xp 00000000 08:06 266216     /lib/i386-linux-gnu/libnss_dns-2.15.so
b0413000-b0414000 r-xp 00004000 08:06 266216     /lib/i386-linux-gnu/libnss_dns-2.15.so
b0414000-b0415000 rwxp 00005000 08:06 266216     /lib/i386-linux-gnu/libnss_dns-2.15.so
b0415000-b041b000 r-xp 00000000 08:06 1459362    /usr/share/locale-langpack/de/LC_MESSAGES/gdk-pixbuf.mo
b041b000-b044a000 r-xp 00000000 08:06 1840816    /usr/share/fonts/truetype/droid/DroidSans.ttf
b044a000-b044c000 r-xp 00000000 08:06 1188030    /usr/lib/i386-linux-gnu/pango/1.6.0/modules/pango-basic-fc.so
b044c000-b044d000 r-xp 00001000 08:06 1188030    /usr/lib/i386-linux-gnu/pango/1.6.0/modules/pango-basic-fc.so
b044d000-b044e000 rwxp 00002000 08:06 1188030    /usr/lib/i386-linux-gnu/pango/1.6.0/modules/pango-basic-fc.so
b044e000-b0451000 r-xs 00000000 08:06 786744     /var/cache/fontconfig/5e10083637a12ecd1bff191eb66bfa2f-le32d4.cache-3
b0451000-b0452000 r-xs 00000000 08:06 814745     /var/cache/fontconfig/c05880de57d1f5e948fdfacc138775d9-le32d4.cache-3
b0452000-b0455000 r-xs 00000000 08:06 786747     /var/cache/fontconfig/603b2eb47209ddb3c5269b217a306167-le32d4.cache-3
b0455000-b045b000 r-xs 00000000 08:06 786761     /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-le32d4.cache-3
b045b000-b045d000 r-xs 00000000 08:06 786762     /var/cache/fontconfig/99e8ed0e538f840c565b6ed5dad60d56-le32d4.cache-3
b045d000-b045e000 r-xs 00000000 08:06 786714     /var/cache/fontconfig/0fafd173547752dce4dee1a69e0b3c95-le32d4.cache-3
b045e000-b0464000 r-xs 00000000 08:06 786765     /var/cache/fontconfig/a6d8cf8e4ec09cdbc8633c31745a07dd-le32d4.cache-3
b0464000-b0467000 r-xs 00000000 08:06 786722     /var/cache/fontconfig/2cd17615ca594fa2959ae173292e504c-le32d4.cache-3
b0467000-b046c000 r-xs 00000000 08:06 786775     /var/cache/fontconfig/bddabcf04192498a6a74911686fc6962-le32d4.cache-3
b046c000-b046f000 r-xs 00000000 08:06 786763     /var/cache/fontconfig/a46337af8a0b4c9b317ad981ec3bdf87-le32d4.cache-3
b046f000-b0470000 r-xs 00000000 08:06 786754     /var/cache/fontconfig/79b7902a698c37d747b157374a08587f-le32d4.cache-3
b0470000-b0471000 r-xs 00000000 08:06 786721     /var/cache/fontconfig/1b70ff56935fd37e75520e134628df26-le32d4.cache-3
b0471000-b0476000 r-xs 00000000 08:06 786728     /var/cache/fontconfig/3fdcac6013931cd7c06449c5f8fab136-le32d4.cache-3
b0476000-b0477000 r-xs 00000000 08:06 786752     /var/cache/fontconfig/6edd069ccec3ba28096b368c434fa861-le32d4.cache-3
b0477000-b0478000 r-xs 00000000 08:06 786767     /var/cache/fontconfig/acf24f57989d82ed5c91b60ef9c3a050-le32d4.cache-3
b0478000-b0479000 r-xs 00000000 08:06 786787     /var/cache/fontconfig/e7071f4a29fa870f4323321c154eba04-le32d4.cache-3
b0479000-b047a000 r-xs 00000000 08:06 786748     /var/cache/fontconfig/617957603a337376ca8784972c6029f5-le32d4.cache-3
b047a000-b047c000 r-xs 00000000 08:06 786771     /var/cache/fontconfig/b5ea634b0fb353b8ea17632d1f9ef766-le32d4.cache-3
b047c000-b047d000 r-xs 00000000 08:06 786713     /var/cache/fontconfig/0d8c3b2ac0904cb8a57a757ad11a4a08-le32d4.cache-3
b047d000-b047e000 r-xs 00000000 08:06 786712     /var/cache/fontconfig/0cbec7fefbf586a62e8b29e50474223e-le32d4.cache-3
b047e000-b0482000 r-xs 00000000 08:06 786766     /var/cache/fontconfig/a755afe4a08bf5b97852ceb7400b47bc-le32d4.cache-3
b0482000-b0484000 r-xs 00000000 08:06 786789     /var/cache/fontconfig/f680583fed5bdc90d95a16af47e16528-le32d4.cache-3
b0484000-b0485000 r-xs 00000000 08:06 786742     /var/cache/fontconfig/5a86461592e14be7c82e45729474f230-le32d4.cache-3
b0485000-b048c000 r-xs 00000000 08:06 786751     /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-le32d4.cache-3
b048c000-b048f000 r-xs 00000000 08:06 786784     /var/cache/fontconfig/de156ccd2eddbdc19d37a45b8b2aac9c-le32d4.cache-3
b048f000-b0491000 r-xs 00000000 08:06 786731     /var/cache/fontconfig/4609d6ed693fb2a61c04ed6a1f4c071e-le32d4.cache-3
b0491000-b0498000 r-xs 00000000 08:06 786764     /var/cache/fontconfig/a6354e3ac43af67bd8d7b8e43c34e49f-le32d4.cache-3
b0498000-b0499000 r-xs 00000000 08:06 786736     /var/cache/fontconfig/4c8bd476623eafb6fe862291a3b05f7d-le32d4.cache-3
b0499000-b04a4000 r-xs 00000000 08:06 786711     /var/cache/fontconfig/04aabc0a78ac019cf9454389977116d2-le32d4.cache-3
b04a4000-b04a7000 r-xs 00000000 08:06 786726     /var/cache/fontconfig/385c0604a188198f04d133e54aba7fe7-le32d4.cache-3
b04a7000-b04a8000 r-xs 00000000 08:06 786760     /var/cache/fontconfig/9451a55048e8dbe8633e64d34165fdf2-le32d4.cache-3
b04a8000-b04a9000 r-xs 00000000 08:06 786778     /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-le32d4.cache-3
b04a9000-b04ab000 r-xs 00000000 08:06 786733     /var/cache/fontconfig/48b6b01af2a6a6e7e7f3fa61998c4afa-le32d4.cache-3
b04ab000-b04ac000 r-xs 00000000 08:06 786757     /var/cache/fontconfig/851315490c06139f6052d4901e9ae814-le32d4.cache-3
b04ac000-b04b0000 r-xs 00000000 08:06 786777     /var/cache/fontconfig/ca37dee8d6057f2a069c1b3d05990269-le32d4.cache-3
b04b0000-b04b1000 r-xs 00000000 08:06 786716     /var/cache/fontconfig/140de4c79e1fe3233d29845b6303d1b0-le32d4.cache-3
b04b1000-b04b9000 r-xs 00000000 08:06 786745     /var/cache/fontconfig/5f38aebfb03f60a9655b5ffadc824a03-le32d4.cache-3
b04b9000-b04bd000 r-xs 00000000 08:06 786724     /var/cache/fontconfig/3047814df9a2f067bd2d96a2b9c36e5a-le32d4.cache-3
b04bd000-b0516000 r-xs 00000000 08:06 786737     /var/cache/fontconfig/51a3e4c21f64d587f5095aba4c4f56c0-le32d4.cache-3
b0516000-b0517000 r-xs 00000000 08:06 786739     /var/cache/fontconfig/56cf4f4769d0f4abc89a4895d7bd3ae1-le32d4.cache-3
b0517000-b0518000 r-xs 00000000 08:06 786773     /var/cache/fontconfig/b9d506c9ac06c20b433354fa67a72993-le32d4.cache-3
b0518000-b051c000 r-xs 00000000 08:06 786770     /var/cache/fontconfig/b47c4e1ecd0709278f4910c18777a504-le32d4.cache-3
b051c000-b051e000 r-xs 00000000 08:06 786720     /var/cache/fontconfig/1a25d991a29b3a619752bca4002717dc-le32d4.cache-3
b051e000-b0520000 r-xs 00000000 08:06 786717     /var/cache/fontconfig/14d493b97896515cad3840ba4896e372-le32d4.cache-3
b0520000-b0525000 r-xs 00000000 08:06 786779     /var/cache/fontconfig/ce677e824a231659fde4a3a246a10ea3-le32d4.cache-3
b0525000-b0526000 r-xs 00000000 08:06 786758     /var/cache/fontconfig/89034621ae2a8922916bb6bfa5799546-le32d4.cache-3
b0526000-b0528000 r-xs 00000000 08:06 786786     /var/cache/fontconfig/e49e89034d371f0f9de17aab02136486-le32d4.cache-3
b0528000-b0529000 r-xs 00000000 08:06 786734     /var/cache/fontconfig/4b14b093aebc79c320de5e86ae1d3314-le32d4.cache-3
b0529000-b0536000 r-xs 00000000 08:06 786781     /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-le32d4.cache-3
b0536000-b0537000 r-xs 00000000 08:06 786769     /var/cache/fontconfig/ae26c1aac6606cb24499bf89ff8f20df-le32d4.cache-3
b0537000-b0538000 r-xs 00000000 08:06 786774     /var/cache/fontconfig/ba9cf83e7ed83db39d062c5a836e9436-le32d4.cache-3
b0538000-b0539000 r-xs 00000000 08:06 786788     /var/cache/fontconfig/f3d4f2ed5c89e879c37f86979022c1df-le32d4.cache-3
b0539000-b053a000 r-xs 00000000 08:06 786782     /var/cache/fontconfig/d69c7f22caf0697490c4d47e6ef04d17-le32d4.cache-3
b053a000-b053b000 r-xs 00000000 08:06 786730     /var/cache/fontconfig/41b81ee6b44c10aca3db1fc8bdaebd36-le32d4.cache-3
b053b000-b0540000 r-xs 00000000 08:06 786715     /var/cache/fontconfig/105b9c7e6f0a4f82d8c9b6e39c52c6f9-le32d4.cache-3
b0540000-b0544000 r-xs 00000000 08:06 786727     /var/cache/fontconfig/3f7329c5293ffd510edef78f73874cfd-le32d4.cache-3
b0544000-b0545000 r-xs 00000000 08:06 786759     /var/cache/fontconfig/8cc03e3a04a09d98b32b781e5f64018d-le32d4.cache-3
b0545000-b0547000 r-xs 00000000 08:06 786755     /var/cache/fontconfig/7ced87123e2d184881c6610d82463bf1-le32d4.cache-3
b0547000-b0548000 r-xs 00000000 08:06 786768     /var/cache/fontconfig/ad2e33cf111390dd78009b3308a88f1b-le32d4.cache-3
b0548000-b054a000 r-xs 00000000 08:06 786743     /var/cache/fontconfig/5b0623c2c1e6dea9559ee397e26a7919-le32d4.cache-3
b054a000-b054d000 r-xs 00000000 08:06 786790     /var/cache/fontconfig/fac9d1061ce4dddb2143955f84876fd7-le32d4.cache-3
b054d000-b05a3000 r-xs 00000000 08:06 786772     /var/cache/fontconfig/b80ce64a4bd0ac846cde5fbdd290c01c-le32d4.cache-3
b05a3000-b05c2000 r-xs 00000000 08:06 786719     /var/cache/fontconfig/198d8fcf01c96d0cf813f74fd759bdb7-le32d4.cache-3
b05c2000-b05cb000 r-xs 00000000 08:06 786738     /var/cache/fontconfig/53d14c92082a93e67d5078324eb314ca-le32d4.cache-3
b05cb000-b05d9000 r-xp 00000000 08:06 263016     /lib/i386-linux-gnu/libudev.so.0.13.0
b05d9000-b05da000 r-xp 0000e000 08:06 263016     /lib/i386-linux-gnu/libudev.so.0.13.0
b05da000-b05db000 rwxp 0000f000 08:06 263016     /lib/i386-linux-gnu/libudev.so.0.13.0
b05db000-b0622000 r-xp 00000000 08:06 263014     /lib/i386-linux-gnu/libdbus-1.so.3.5.8
b0622000-b0623000 r-xp 00047000 08:06 263014     /lib/i386-linux-gnu/libdbus-1.so.3.5.8
b0623000-b0624000 rwxp 00048000 08:06 263014     /lib/i386-linux-gnu/libdbus-1.so.3.5.8
b0625000-b0627000 r-xp 00000000 08:06 262197     /lib/libnss_mdns4_minimal.so.2
b0627000-b0628000 r-xp 00001000 08:06 262197     /lib/libnss_mdns4_minimal.so.2
b0628000-b0629000 rwxp 00002000 08:06 262197     /lib/libnss_mdns4_minimal.so.2
b0629000-b062a000 r-xs 00000000 08:06 786729     /var/cache/fontconfig/3fe29f0c9fa221c8ee16555d4835b3ab-le32d4.cache-3
b062a000-b063e000 r-xs 00000000 08:06 807717     /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-le32d4.cache-3
b063e000-b0667000 r-xp 00000000 08:06 1182872    /usr/lib/i386-linux-gnu/gio/modules/libgvfsdbus.so
b0667000-b0668000 r-xp 00028000 08:06 1182872    /usr/lib/i386-linux-gnu/gio/modules/libgvfsdbus.so
b0668000-b0669000 rwxp 00029000 08:06 1182872    /usr/lib/i386-linux-gnu/gio/modules/libgvfsdbus.so
b0669000-b06ad000 r-xp 00000000 08:06 1186859    /usr/lib/i386-linux-gnu/libibus-1.0.so.0.401.0
b06ad000-b06ae000 r-xp 00043000 08:06 1186859    /usr/lib/i386-linux-gnu/libibus-1.0.so.0.401.0
b06ae000-b06af000 rwxp 00044000 08:06 1186859    /usr/lib/i386-linux-gnu/libibus-1.0.so.0.401.0
b06b1000-b06c9000 r-xp 00000000 08:06 1459491    /usr/share/locale-langpack/de/LC_MESSAGES/glib20.mo
b06c9000-b06fe000 r-xp 00000000 08:06 1187797    /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
b06fe000-b06ff000 r-xp 00034000 08:06 1187797    /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
b06ff000-b0700000 rwxp 00035000 08:06 1187797    /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so
b0700000-b0800000 rwxp 00000000 00:00 0
b0802000-b0817000 r-xp 00000000 08:06 1182870    /usr/lib/i386-linux-gnu/gvfs/libgvfscommon.so
b0817000-b0818000 r-xp 00014000 08:06 1182870    /usr/lib/i386-linux-gnu/gvfs/libgvfscommon.soAbgebrochen (Speicherabzug geschrieben)
All I can do is restart the computer, and then the same procedure as described is going on.
Edit: restart doesn't help always, but what helps is to remove the .stereo-tool.rc-file in the home-directory. Then, every settings from the last session is lost, but ST starts normal.
PostPosted: Sun Jun 30, 2013 1:19 pm
BETA724-023:
Shows dots now when I reattach a source to to in_l/in_r. But ST does not appear to get any audio. Jack works fine with other programs (e.g. audacity recording from my jack source).
PostPosted: Sun Jun 30, 2013 7:51 pm
- RadioFreak: after about 2 hours normal operation, the mpx-output gets lots of hiccups, and is unusable. I don't know if it has something to do with JACK and my other applications running at the same time, will check this
Forget about this - isn't ST that causes the hiccups! Sorry :)
PostPosted: Sun Jun 30, 2013 10:21 pm
BETA724-023:
I'll work on the other (clearer) bugs first, and then I'll just hope that one of these is related to what you see. Just a quick check: Could you check the CPU load? Just to make sure that Stereo Tool is doing something.
PostPosted: Sun Jun 30, 2013 10:26 pm
@Brian: Actually it wouldn't really surprise me if the performance on newer Intel compilers is improved now. I've rewritten, removed and optimized a lot of code in the last few months. I'm not too sure though if putting too much effort into getting better performance from some product from some vendor is a good idea - since it could very well be that decisions were made by the Intel compiler team that are causing things in my software to be less optimized. Before version 11 of the compiler, upgrading to newer versions had no effect or caused a small improvement, however version 11.0 and later versions cause a considerable drop in performance. The issues I posted on the Intel forum are solved, that's why I said that the newer version of the compiler might not give a performance drop anymore.
The GNU compiler seems to do a pretty good job at optimizing too now, looking at the Linux version performance. Definitely better than the latest Intel compiler versions.
PostPosted: Sun Jun 30, 2013 11:31 pm
BETA724-023:
CPU load is quite high, between 100 and 115 % in top even though the CPU setting in ST is at 20%.
PostPosted: Mon Jul 01, 2013 3:36 am
In the latest Windows SA Beta I am getting clicks after about 20 - 25 minutes. Hitting the Restart Sound card button fixes it.
Clipper
PostPosted: Mon Jul 01, 2013 5:26 am
BETA724-023:
Windows: Synchronize fixed.
I still don't see those numbers "M" and "x"
