Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 110 11 12 13 14213 Next
PostPosted: Wed Mar 09, 2011 1:10 am
Gooooooooooooooooood News !!!!!!!!!!!
Using the latest beta i found that SCA 92 khz works too !!!!!!! ( not only 67 khz but 92 too !!!!!!!!! ) :idea: :idea:
Both SCA freqnencies sound loud and clear!! ( FM mode of course, AM mode doesn't work at all! :) just remove it :)!
So, using a realtek onboard soundcard we CAN broadcast both SCA frequencies !! :geek:
Hi Camclone,
This isn't really possible - I think 92 kHz only works if you keep the input level very low (below around 50%, -6 dB). Higher peaks will give very annoying effects - since you need output frequencies upto 99 kHz and the theoretical maximum possible output freq is 96 kHz. (That's actually (96 - 92) / 7 = 4/7 of the normal maximum input level; in practice I don't think you will reach 96 kHz. Also at such high frequencies be VERY VERY careful about spikes that may cause your signal to disturb other stations!!!
I will indeed remove AM mode. (Didn't have time yet)
( can you make the SCA freqnencies to NOT lower the volume of normal sound when they are enabled ? ) MPX limiter doesnt limit SCA as i can see now :( , is this possible to make SCA to now lower the overal volume ?
I'm a bit confused here. If I add an SCA carrier, I *need* to lower the rest of the audio to make room for it. I read that in the US (!!!) stations are allowed to increase their maximum 'swipe' with half of the SCA volume (so SCA volume = 10% then they can go to 75 + 5% = 78.75 kHz), with a maximum increase of 10%. However this may be different elsewhere.
The MPX limiter DOES take the SCA signal into account, but it does not affect it - that wouldn't be very useful anyway because the SCA signal is AND SHOULD BE completely constant in level.
PostPosted: Wed Mar 09, 2011 10:06 pm
ok, so, it's better to keep the " auto volume level control " if SCA is added to the MPX signal.
I confirm again that using a realtek onboard soundcard i was able to broadcast 1) mono signal 2) stereo pilot 3) stereo signal 4) rds 4) sca1 5) sca 2 , at THE SAME TIME, all these together at 74 khz !
i just lost 20 % of my normal audio levels ( normal sound was 10+10 lower becuse of SCA), that's ok!
so,
it works! i am sure about that, , i just noticed that SCA at 92 khz has more noise . that's not a problem for me and it depends on the SCA reciever.
everything is working fine on the SCA code.! thank u for that!
( i AM BROADCASTING 3 , 3 , 3 !!! different music programs in ONE FREQUENCY on FM ! , this IS a very big deal for me! , 1 normal program and 2 different programs for supermarkets!
PostPosted: Sun Mar 13, 2011 3:30 am
BETA620-011:
Fixed a few bugs in Loudness processing, especially at lower latencies:
- Very deep bass protection is now enabled at all latencies, and Deep bass boost works at all latencies.
- Fixed a bug in non-strict bass clipping which caused 'crackling' sounds when loud bass sounds were present.
- Default settings for bass clipping are slightly (6%) reduced to greatly improve bass quality (especially noticeable at lower latencies) - note that without 'very strict' filtering the bass comes out a bit louder anyway so this has very little effect. Bass clipping is set to 94% now, higher levels re-introduce the crackling sound described above.
- Fixed a bug at latency 512 and 1024 that may have caused strange bass effects (I don't know if that was really the case, and I don't know what kind of effects.)
Re-load the default settings to get the improved bass clipping values!
Note that if you're using Multiband at default settings, you'll probably never get such loud bass sounds unless you set Loudness to a very high level.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-011.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-011.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-011.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-011.dll
Command line version: http://www.stereotool.com/download/ster ... 20-011.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-011 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-011 NOT AVAILABLE
- Add buffer and filter for SCA output (SCA1 ok, SCA2 not yet) 1 day
- Finish AGC improvement ? - make mono value configurable (replace checkbox by slider) 1 hour --> NO, not needed - anything else needed?
- Fix Punch making it dynamic will cost 1 day
- Check what to do with new filters (such as bass AGC) - keep them, remove them, change them?
- Release 1 hour
PostPosted: Mon Mar 14, 2011 12:32 am
Hmmmm, I just saw that there is a BUG on RDS time display and timezones :(
My operating system has gmt +2 ( this is my timezone ) and stereotool also shows +2 ...BUT the RDS recievers show 2 hours more than should !
if it's 1200 , rds recievers show 14 00 ! :(
can y fix it plz ?
or what can i do to solve it temporarly ?
( everything else is OK!! , the latest betas have a value of more than 8.000 euros if they where ..hardware! :)
excellent work!
PostPosted: Mon Mar 14, 2011 12:42 am
viewtopic.php?f=15&t=2715
PostPosted: Mon Mar 14, 2011 2:25 pm
BETA620-012:
Fixed time bug in RDS (oops - I was sending out the LOCAL time + correction, instead of GMT time + correction...)
Also made files a bit smaller.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-012.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-012.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-012.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-012.dll
Command line version: http://www.stereotool.com/download/ster ... 20-012.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-012 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-012 NOT AVAILABLE
- Release 1 hour
PostPosted: Mon Mar 14, 2011 3:28 pm
Hans, one more thing, have to make AGC variables stored.!
Sexy Girls in your city
PostPosted: Mon Mar 14, 2011 3:40 pm
YES PLEASEEE
PostPosted: Tue Mar 15, 2011 4:25 pm
BETA620-013:
New AGC settings saved. (Bass_AGC and SCA channel settings not yet).
Slightly decreased file size again.
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-013.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-013.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-013.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-013.dll
Command line version: http://www.stereotool.com/download/ster ... 20-013.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-013 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-013 NOT AVAILABLE
- Add buffer and filter for SCA output (SCA1 ok, SCA2 ok) 1 day
- Release 1 hour
PostPosted: Tue Mar 15, 2011 6:13 pm
Hans > don't know if this is possible but' is there a way you can make the preamp go higher than X40?
can you make if so you can put it to x70 if needed....just that some times in vids and music its been recorded so low that putting it up to x40 is just not high enough, if you cant don't worry about it.
like a preamp boost of some-kind that will not interfere with anything else in stereotool.?
