Post new topic  Reply to topic  [ 180 posts ]  Go to page Previous 19 10 11 12 1318 Next
PostPosted: Thu May 24, 2012 5:32 pm
Ok, there were 2 things wrong with bass at 4096! And I fixed only one :(
The other is now fixed as well, but right now bass shaping doesn't work at latency 4096. I'll post a new version when that's fixed. In short, I think you should expect the clarity that you're used to at 4096 combined with the bass quality from 1024.
(What was wrong was a form of bass post ringing, although it didn't sound like that at all).
PostPosted: Thu May 24, 2012 5:37 pm
How much difference is expected in highs content between beta 008 and beta 011? I find beta 011 quite dull - as in less highs? Currently trying out neta 009...
EDIT: I had De-clipper disabled till beta 008 - somehow had the feeling keeping it disabled sounded tad brighter. Now in beta 011, I percieve enabling de-clipper as better. Just first impression.
visit website
PostPosted: Thu May 24, 2012 5:49 pm
Beta 011 :?: :?: :?:
by GAP
"Less is More" (Bob Katz)
PostPosted: Thu May 24, 2012 6:32 pm
Apologize. I meant beta 010...
visit website
PostPosted: Thu May 24, 2012 6:44 pm
Should be about the same! Can you post or if you don't want to mail me your stettings?
PostPosted: Fri May 25, 2012 12:19 am
New version is building now... To me it sounds a lot better @ 4096 (no changes at other latencies). I have also adjusted "Bass shape" to behave the same at all latency settings (to get the same behavior as before @ 2048, you need to double the old value; no change @ 4096).
CPU load is a bit higher, I have not yet tried to reduce it yet. There's also a new slider that can be used to choose between very clean clipping or slightly more "smoothing" of sounds in time (pre and post ringing), giving a louder sound with less spikes (so you can reduce Strictness further!). Because the new improved filtering @ 4096 already leads to a drop of about 0.2 dB and 0.3 dB louder spike levels, I've set it to 25% by default which results in a signal that's very similar to what the previous versions had.
PostPosted: Fri May 25, 2012 12:22 am
Can't wait :D :D
http://www.kanal80.net
Best 80's & 90's Music
PostPosted: Fri May 25, 2012 7:23 am
BETA011:
Improved bass clarity (potentially other frequencies as well) at latency 4096. CPU load is higher than before at 4096, I'll look into that later.
Added Time smoothing slider.
Made Bass shape behavior the same at all frequencies, good value seems to be 0.50/160
Stand alone: http://www.stereotool.com/download/ster ... 31-011.exe
DSP: http://www.stereotool.com/download/dsp_ ... 31-011.exe
VST: http://www.stereotool.com/download/vst_ ... 31-011.dll
PostPosted: Fri May 25, 2012 11:51 am
I hear more vocals clarity on Beta10 than latest Beta011. anyone else?
Sexy Girls in your city
PostPosted: Fri May 25, 2012 5:11 pm
Should't be...
Anyway finally good bass :)
