Hi Honda ..
I just reinstaled windows on friends pc .. and i noticed SoundChip ALC888
I saw same problem with setting card to work on 192kHz.
i take time to try other things to get it to work in 192kHz...
in short ..
Download and try this drivers! Works on this PC !!
http://download1.msi.com/files/download ... all_mb.zip
i've tried that driver, but no 192 khz option or something in de realtek sound manager seen. I've also tried the vista/win7 driver, but no succes too
I've installed my release candidate of windows 7, it takes more memory as xp does, but the cpu usage is quite the same as in xp. I've installed the win7 driver and i could choose the output sample rate
But there is an problem my windows7 release candidate is just useable for 30 days. Then i have to buy a code to activate windows. I don't want to buy a windows 7 code for 119 euro's (upgrade edition; if i hadn't a value xp i should pay 199 euro's for windows 7
) So i don't want to do this because for about 100 euro's i could get better a nice esi maya, which should work also whit stereotool's rds and stereo (isn't?) and does works with xp (correct me if i'm wrong)
So i just like to use my realtek with xp
so i hope you or somebody else has an windows xp solution. For now i work whit windows 7 but that just for 30 days from now on....
Note: could you tell me what you did exactly whit your friends windows xp computer to get an 192 khz output?
thanks in advance!
