Post new topic  Reply to topic  [ 15 posts ]  Go to page Previous 1 2
 Post subject: Re: 7-Elements by GAP
PostPosted: Mon Jan 27, 2014 2:25 pm
Thanks for the explanation. One more question though. How come the Bandpass is set to 25hz and 16500Hz instead of say 20Hz and 20000Hz (i.e. human hearing)? Is that for FM radio stations or did you find that nobody could notice those frequencies being cut?
PostPosted: Mon Jan 27, 2014 2:54 pm
The truth is that the limitation of bandwidth and mainly of 16500 Hz, the use of streaming issues, usually do not tolerate codecs beyond those frequencies or generate artifacts.
The limit of 25 Hz, is a value that I like it for this processor, to make better use energy from the bass.
Anyway, you can try changing the setting values ​​you say, I think you can not notice much difference between these and the other values​​. ;)
by GAP
"Less is More" (Bob Katz)
PostPosted: Wed Feb 26, 2014 4:21 am
After a few days of vacation, I leave a version with some fine tuning. ;)
Built to last Beta 36.
GAP_7-Elements_v0.5.sts [59.03 KiB]
Downloaded 351 times
by GAP
PostPosted: Sun Mar 09, 2014 6:10 am
Here is some general settings, ND, MB, ST, PBass, PHighs, SB, Advance Clipper.
Try, do not repent. ;)
GAP_7-Elements_v0.6.sts [59.06 KiB]
Downloaded 387 times
by GAP
PostPosted: Sun Apr 06, 2014 4:36 am
The last version for this preset.
To test the Advance Clipper, off the SB. :)
Worth trying, better definition of the Highs and the top of the voices!
Clipping a little more, but not noticeable. ;)
GAP_7-Elements_v0.7.sts [59.06 KiB]
Downloaded 592 times
by GAP
