Post new topic  Reply to topic  [ 29 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: B-Natural (Testing)
PostPosted: Fri Jul 12, 2013 12:39 pm
I think not at all.
PostPosted: Fri Jul 12, 2013 12:47 pm
You have this running on the E8400/8500?
Oh well.... This, like the new multiband, is on hold until I can get a new system. Probably going to be an i3 Haswell or a FM2+ Kaveri (if performance is close).
PostPosted: Fri Jul 12, 2013 2:43 pm
Yea on my E8400 OCed.. 65% with 1 core working.
PostPosted: Fri Jul 12, 2013 3:43 pm
I'm planning to rewrite ND from scratch soon. Currently it's an 18 (!) bands expander - that's just waaay too much. And the sharp filters (same as with the old multiband) cause some artifacts too.
PostPosted: Fri Jul 12, 2013 5:32 pm
Eagerly awaiting the re-write.
While for me even the current implementation sounds great when compared to not using the filter, I am sure if you say the re-write will sound better, the difference would be impeccable!
visit website
PostPosted: Fri Jul 12, 2013 5:43 pm
I can't find any male voice on track1 ?
track2 - exactly what i said.. i opened a bit too much upper mids so 'some' voices/instrumends (constant tone) came out bit louder. Actually this is problem for Natural dynamics.
Anyway.. i made some changes...
I actually quoted "Waiting" to exemplify how good Emma Hewitt's voice sounds.
The problem with male vocals is 2 pronged:
1. Lack of deep bass - Consider Josh Groban's rendering in Troy - "Remember Me". The singer has a baritone voice. The deep lows in his voice is missed in your preset.
2. As even Gpagliaroli would have noticed, highs are too much suppressed. This affects even non-vocal sounds. It gives the impression of the sound being less open. I can see in MB that the last band is clamping highs a lot. Consider listening to tracks of Marc Anthony , one other - Daniel Bedingfield - "If You Are Not The One..".
If could tweak the preset considering above two points, you would create a gem!
visit website
PostPosted: Fri Jul 12, 2013 9:31 pm
B-Natural_test14.sts [51.24 KiB]
Downloaded 395 times
Changed some things.. Hard to make ND and MB to not fight each other. :)
PostPosted: Sat Jul 13, 2013 5:07 am
Hi Bojcha.
Nice and clean sound. This is something different ;-) Testing your preset (14) this hole weekend on line. Format is 70s till 00s, usesing the Last beta st..
Thank you.
Home: SummerXl - TuneIn: Summer-Xl SummerXl stream 192 kbps: SummerXl SummerXl
PostPosted: Sat Jul 13, 2013 12:19 pm
Hey digital, thanks.. listening your stream also...
edit: Sounds very nice and i see it handles jingles-over-track very well.. :)
PostPosted: Sat Jul 13, 2013 4:55 pm
Found bad thing happen with usually voices in WB1 and WB2 compressor(s)... will fix that asap...
