Post new topic  Reply to topic  [ 103 posts ]  Go to page Previous 1 2 3 4 511 Next
 Post subject: Re: Stereo Tool 7.00
PostPosted: Thu Dec 13, 2012 2:47 pm
You misunderstood.Its the New release version Stereo Tool 7 that does not work ie no GUI
I meant: Which beta was still working? That way I can look what I've changed since.
PostPosted: Thu Dec 13, 2012 2:54 pm
New look atomatically means - better sound. :mrgreen:
PostPosted: Thu Dec 13, 2012 2:55 pm
Yeah :) But well it also sounds better :)
PostPosted: Thu Dec 13, 2012 3:00 pm
I have this one installed
VST: http://www.stereotool.com/download/vst_ ... 33-063.dll,which functions correctly.
PostPosted: Thu Dec 13, 2012 8:17 pm
I also haz question:
Does Noise Gate use the values before preamp or after preamp?
PostPosted: Thu Dec 13, 2012 10:21 pm
Before. Pre Amp has no effect on declipper & noise gate.
PostPosted: Fri Dec 14, 2012 12:20 am
hmm.. not good for noise gate. *i think*
PostPosted: Fri Dec 14, 2012 1:38 am
A major new version. I cannot wait to try it. Thank you Hans
PostPosted: Fri Dec 14, 2012 2:05 am
I agree what else would be benefit for this input gain slider?
PostPosted: Fri Dec 14, 2012 2:09 am
I wonder if we are thinking the same thing?
Say noise level coming in is -50 dB, Noise gate is set to -40 dB.
Then all noise is removed.
Increase Pre Amp, regardless how high, still all noise gets removed.
Increase Input Gain far enough, and some noise will pass.
