Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Fri Oct 20, 2023 5:29 pm
I'm glad you're going to try to do this. If you want, I could also send you a zip file of newer music, only now that there is no more Yugoslavia, Serbia, Bosnia and Herzegovina and Croatia. From those three countries, I could send you music from the 90s, 2000s and beyond.
Below I am sending you a zipped file of mp3 files of older Yugoslav folk music, and pay attention to the drop in music on the following file names:06. Prođi samnom ispod duge.mp3
This is the original name of the file and in translation it means: 06. Walk with me under the rainbow.mp3. Below I am sending you a link to download the files, and the files are larger, so I sent them to the mega server. The link is:
https://mega.nz/file/HBEVkJZI#_-AZjWsiq ... IIPpQhcJBE
Listen to how it sounds and see what can be done there.
I've downloaded the zip, I will have a look but it will be somewhere later next week.
Hey, this is really good! Thanks for sharing. (I'm a house monkey too). You maybe lost a little too much treble with v1.1, but it sounds much better than v1 overall. Transparent. Like you're just listening to the music, but with a bit more oomph.
Thanks, that's exactly what I was going for.
I've combined the treble of v1 and the bass of v1.1 EQ settings and put them in the first post, if you're on ST 10.10 you should be able to load it seperately.
PostPosted: Sat Oct 28, 2023 11:23 pm
@slauf
I should have something to test for you in a couple of days.
If it's okay with you, I'll PM you by then.
PostPosted: Wed Nov 01, 2023 1:39 am
Final version of the preset in the first post.
PostPosted: Fri Nov 03, 2023 12:04 am
@slauf
Maybe you didn't get a notification because I didn't but I have replied to your PM a couple of days ago.
PostPosted: Fri Nov 03, 2023 6:54 am
This is really interesting, so I would ask Hansa and Tom Evers to correct this mistake. So, when a private message is sent here on the forum, notifications do not come to the e-mail, so I did not receive a notification by e-mail about your reply to the private message, so I replied to you now, so please reply to the private message. I'll listen to your preset today and get back to you.
@slauf
PostPosted: Mon Dec 04, 2023 2:40 am
The station has a new computer and runs ST 10.11 now at 150% audio quality so I couldn't resist revisiting the preset.
PostPosted: Mon Dec 04, 2023 2:45 am
Another thing I added to the station is to have more changing RDS RadioTexts than the standard A and B ones, with the help of taskt, a free automation program.
Zip in first post.
PostPosted: Mon Dec 04, 2023 4:25 am
Instructions to set up the RDS RadioTexts in the zip.
PostPosted: Fri Jan 19, 2024 1:27 am
House One XL preset, Xtra Loud and more bass in first post.
PostPosted: Sat Jan 20, 2024 11:06 pm
House One XL preset updated, adjustment of the clippers to eliminate some tiny overshoots in the bass.
